ok pins 1-9 of the 3915
1| 3.8
2|.4MV(basically zero)
3|5.44
4|.4MV (same as 2)
5|.64 V
6|1.5
7|3
8|3
9|5.4
The Led's will light when not connected the the circuit
i saw that i had connected the pot wrong i corrected that and the leds would light but my leds are just misc. ones from my drawer and one of my red leds meaning dry is on always i don't know if it is the leds or the circuit because the other leds just dim when i adjust the pot until they are barely visable
i put in a switch to change between dot and bar and when it is in dot i don't see anything please help
EDIT: when in dot i do see one green led (second from first meaning wet) when the probes are dry
does the 3915 work high number down?
whoops i realy messed this project up
i connected pin 1 of the 3915 in the wrong spot i connected it next to the led for pin 10 on accident so that probably explanes some of the wierd things
