W
Wolfgang Allinger
- Jan 1, 1970
- 0
I have a BOSS HC-2 hand clapper that is broken
The problem is that it makes crackling noise when I touch the pcb.
Since the audio connecters are wired to the pcb it crackles whenever
the cord is touched.
I have almost zero experience in repairing stuff but I want to learn,
and since it's not a very expensive item, I think it makes sense to
practice on it. Taking it appart it looked to me as at least of the
capacitors had leaked? Could that generate crackling noise?
I took this picture:
http://www.bgst.dk/pcb.jpg
What do I do?
I think, that's some glue (sometimes waxe) to fix parts and not caused
by leaked capacitors. It's not a perfect but cheap/common method to
prevent failures from vibrating parts or changing values/adjustments in
some high-frequency application.
I don't think, that that's your problem. Look for could solder points,
bad (corroded) contacts, broken copper, cracks on the pcb...
Saludos Wolfgang
