Please help me identify this burnt piece
Zip112
Nov 16, 2015
18
The images on Android can be easily cropped using the stock Gallery app. Just open the menu and choose "crop".
Zip112
Nov 16, 2015
18
there ya go :)
can it resize images as well ?
I found it in my gallery app, but I wouldn't be surprised if it depends on the android version. In mine I hit Edit, then menu, then Export, and then it lets you save the image with a new size.
Martaine2005
May 12, 2015
5,318
That's what I love about this forum!
The OP helps a moderator!
See, we are all the same really...!!
Martin
Zip112
Nov 16, 2015
18
Martin
All the same as in we all have eyes and hands. I'm still working on the beginners books for electronics! :) I'm actually looking into getting my first oscilloscope soon, and I'll probably be searching this forum for relevent information.
Martaine2005
May 12, 2015
5,318
Well Emma is definitely more interesting!..Or at least was 20 years ago!
But don't feel bad John. Your great big crimps work fine! job done.. And good job too.
Martin
Tha fios agaibh
Aug 11, 2014
2,253
Just a guess here, but I think this is a 300w heater. If that's the case, 12awg would work, but I'd go with #10 thhn, thwn or similar 90c rated insulation.
At any rate, you know it doesn't have to be larger than the incoming feed.
Zip112
Nov 16, 2015
18
You agree about celebrities from the 90s being old? Or about the wattage? Or maybe BOTH? :)
Can you give us the individual ohm readings of each element?
I will if/when I open it. I just realized that the unit is closed with rivets instead of screws, so that'll slow me down some.
But I found some more information from the manufacturer of the heater. I'm pretty sure the model I have has these specs (the manufacturer's page doesn't list anything else): 12V ELECTRIC HEATER WARMER 1,400 BTU
And then I found this page that has a very-similar-looking heater, except that it has 4 heating rods instead of 3: http://dcthermal.com/catalog/sa12-2000 . That's the weakest heater made by that company (listed as 220 watts at 12 volts), yet it has 3674 BTU’s. So I think we can assume that the wattage of the heater I'm working on is lower.
If this heater really is using less power than 220 watts, then how much does that change of our above discussion? Maybe regular wire-nut connections would be fine here? Maybe this power didn't burn up the old silicone connector?
I can test how much current it's drawing once I get it hooked up to a power source, but I'm not at that stage yet because I have to pull some junk out of the insides of the heater, like a wasp's nest.
