Please help me identify this burnt piece
Zip112
Nov 16, 2015
18
This piece was connected to the wiring for a small 12 volt heater inside a tractor cab. I'm guessing it's a fuse, but I'm not positive. I can't read the numbers on the back side because there is burnt plastic covering all of the numbers except the first 2, which is "22". The front side only says "3M".
If it is a fuse, is there any way I could go about replacing it, without knowing the exact specs for the fuse?
The 3rd picture is after I pried off the cover that says "3M".
Thanks!
Zip112
Nov 16, 2015
18
Davenn: Thanks a lot! A simple connector was my 2nd guess, but I had the assumption it was a fuse because the person asking me for help with it said it was a fuse. It definitely looks just like the piece in that link you posted.
Tha fios: I haven't discerned yet how many wires were coming out of it, because everything in the area was so burnt up, including with wires melted together.
If it is a simple crimp connector, would you guys guess everything got burned up because of a simple short?
Zip112
Nov 16, 2015
18
Sorry about all the attached images. I didn't realize they were getting attached, so I ended up posting an external link. The attached images weren't showing up on the preview either.
14,487
its a 3 wire connector
Tha fios agaibh
Aug 11, 2014
2,253
Hopefully you have a diagram you can follow.
You might be able to cut off the burnt portion of the wires and resplice where that splitter connection was.
Zip112
Nov 16, 2015
18
Thanks. I'm guessing it'll be simple to figure out once I cut out the burnt portions. There are 2 devices hooked up to a 12v battery: the heater and the windshield wipers.
I'll probably just use some simple wire nuts with electrical tape over them. The inside of the cab never gets wet.
14,487
Those are garbage imo.
have never had any problem with them, 10's of 1000's of them doing telecoms cable jointing
the problem comes when they are used when they shouldn't be, in higher current situations as the OP's use suggests
the multiple amps to power a heater should never be put through this style of connector
14,487
as in my last post ... I was typing when you posted
DONT use these type of connectors in this situation
Martaine2005
May 12, 2015
5,318
That image 1035 looks just like a good find of pound coins with my metal detector!
Martin
Zip112
Nov 16, 2015
18
This is great info. Thanks.
Since it looks like the connector was the main source of the "explosion", do you think it's more likely that the connector was the cause of the failure? Or is it possible that there just happened to be a short near the connector?
Martaine2005
May 12, 2015
5,318
I'll have my 10 cents worth here..
No, it is just a connecter. Likely to be a short a long the line somewhere.
Unless it was completely over loaded. I have never seen one like that for telecom use.
Martin
Tha fios agaibh
Aug 11, 2014
2,253
Use these, with a screw and nut thru the 3 holes. Then insulate with a liberal amount of good quality electrical tape
Tha fios agaibh
Aug 11, 2014
2,253
No, my money is on the cause being heat caused by the high resistance from that garbage connector.
