pls equivalent transistor d2396
kellys_eye
Jun 25, 2010
6,512
They commonly drop the '2S' designation from such device numbers so you're looking at the 2SD2396 which is an NPN Darlington, TO-220 package, 30W, Vceo=60V and Ic=2A, hfe=1000 and Ft=40MHz.
What is the current application for the device you have?
If NPN Darlington is correct then you can use the parametric search option at alldatasheet.com to find others that match
http://category.alldatasheet.com/index.jsp?sSearchword=NPN DARLINGTON &sPage=1
