Plz help ! Reed switch fails within a few operations
j37prakash1
Jul 15, 2011
6
I need to design a circuit to switch on a warning lamp or sound a hooter when a door is opened and the reed switch is activated by the magnet. I have herewith attached the circuit diagram of the test setup. My problem is that the reed switch fails within a few (3 or 4) operations though the current measured is in very small units.
Kindly advise me how to go about it to solve the problem.
Hero999
Oct 28, 2007
2,433
I assume you're using 110VAC, the DC is a typo?
Even if the steady state current is low, a large current will flow for a short time when the capacitor charges which is probably what's causing the switch to fail.
j37prakash1
Jul 15, 2011
6
Oh I see Hero999! Then what should I use to substitute the circuit ? Pls explain
Hero999
Oct 28, 2007
2,433
Have you tried putting the reed switch on the 24VDC side?
