polarity protection with diode between vcc and gnd
Kardo22
Mar 7, 2014
36
Is it OK to do it like on the picture.
To protect circuit from power connector inserted the wrong way.
I'm thinking of this solution a voltage drop wouldn't be good.
Power is supplied by a common benchtop DC power supply, current limited to 200mA.
14,317
It is o.k. if the diode can withstand the power dissipation produced by the current (approx. 140 mA @ 200 mA).
An even better protection scheme would include a fuse between the diode and the positive input. That way the fuse will blow if wrong polarity is applied, thereby protectiong the circuit completely.
duke37
Jan 9, 2011
5,364
Battery driven equipment can often run on lower than the nominal voltage. I would try a diode in series with the supply and see it it works satisfactorily.
There is a cunning circuit using a FET which is only turned on with the right polarity. I have never tried this.
duke37
Jan 9, 2011
5,364
I have had a fooster and found the circuit I was after. The diode is within the FET.polarityprotecct001.jpg
HellasTechn
Apr 14, 2013
1,579
Dont use this topology because you risk shorting and burning your psu if inserted the wrong way.
Better use a fuse in serries as suggested before or place the diode on one of the rails with correct direction.
as for the above circuit i have also never used it.
HellasTechn
Apr 14, 2013
1,579
if you use the fuse make sure you connect it like this :
