Hi, I have a portable induction cook top (Tramontina, model 81500/108) that stopped working. I found the fuse was blown, so tried bypassing it to see if that was all it was. A mistake, as the bridge rectifier blew. Replaced that, but the fuse blew again, so replaced the fuse and both IGBTs. Now it stays on, but it flashes an error code EA. When I press the "on button", it changes to flashing error code Eb. No other symptoms. Fan doesn't come on. It's hard to find anything on these codes, but I believe it is related to detecting the temperature. So I tested the sensors. The thermal cutoff is at near zero ohms (when disconnected), and the thermistor is at about 110k ohms (when disconnected), both normal I believe. What's more, when I hold the thermistor in my fingers while measuring, the resistance slowly decreases. I believe this is also correct behavior. I don't know what to check next. Any help on these codes and what to do/check, or pointing me in the right direction, would be greatly appreciated. Thank you!
