[email protected]
- Jan 1, 1970
- 0
I need to calculate potential in a nonuniform conductor. The complete
problem is
2 dimensional, but even 1D is causing me trouble.
In the 1D problem, you have a 1D conductor of length 3l. The first l
has a
conductivity of k and the remaining 2l of the conductor has a
conductivity of
2k. The two sections have the same resistance. If a voltage is applied
across
this conductor, the both of the sections will drop half the voltage,
and the
voltage change in each section will be linear.
Here are the the equations:
Let J be current density, E be the electric field and V be the
potential.
Since there is no free charge:
div J = 0.
The current is related to the field via the isotropic but not constant
conductivity k:
J = k E.
And the field is the gradient of the potential V:
E = grad V.
Putting this together gives:
div (k grad V) = 0.
In 1D (dimension x) this is:
dk / dx * dv/dx + k * d^2 v / dx^2 = 0
d^2 v / dx^2 = - dk / dx * dv/dx
Taking a finite difference approximation gives:
k(i) * ( v(i-1) -2 v(i) + v(i+1) ) / D^2 = -(k(i+1) - k(i-1))/2D * (v(i
+1) - v(i-1))/2D
where D is the grid spacing, and i is the index which is the descrete
position.
This comes out as:
v(i) = = (v(i+1) * ( k(i) + (k(i+1) - k(i-1))/4) + v(i-1)*(k(i) - (k(i
+1)-k(i-1))/4))/ (2 * k(i))
which can be iterated. This is the relaxation solution for the
differential equation above.
If I solve the above equation, for the problem above, I seem to get
the right
answer (the middle voltage gets very close to half the total voltage,
butit
takes a long time to converge). However, if I make the conductivitites
significantly different, then the equations become unstable and I
can't get an
answer.
Can anyone help?
-Ed
I have a simple solver in matlab. Here is the code:
xs = [1 : 90 ]; %Positions
vs = 0 * xs; %Voltages
rs = 0 * xs; %Conductivities
rs(1:30) = 5;
rs(31:90) = 10;
while 1
vs(1) = 1; %Boundary conditions: 1 volt at the left edge
vs(90) = 0; %Boundary conditions: 0 volts at the right edge edge
v2 = vs;
for i=2:89
v2(i) = (vs(i+1) * ( rs(i) + (rs(i+1) - rs(i-1))/4) + vs(i-1)*(rs(i)
- (rs(i+1)-rs(i-1))/4))/ (2 * rs(i));
end
hold off
plot(xs, vs, 'g');
hold on
plot(xs, v2, 'r');
vs = v2;
end
problem is
has a
conductivity of
across
and the
potential.
div J = 0.
conductivity k:
J = k E.
E = grad V.
div (k grad V) = 0.
+1) - v(i-1))/2D
position.
This comes out as:
the right
butit
can't get an
answer.
Can anyone help?
-Ed
rs(1:30) = 5;
rs(31:90) = 10;
while 1
v2 = vs;
for i=2:89
end
hold off
plot(xs, vs, 'g');
hold on
plot(xs, v2, 'r');
vs = v2;
end
