Martaine2005
- May 12, 2015
- 5,317
- Joined
- May 12, 2015
- Messages
- 5,317
Correct.If you apply dual supply topology then your signal gets amplified between +Vcc and -Vee.
I disagree. The amplification is between +Vcc and 0V.In case of single supply the amplification is between +Vcc/2 and -Vcc/2.
I agree , I meant to say that for example if you are using 12 volts the amplification will be between +6 voltsCorrect.
Also, many car amplifiers are single supply and are bridged for almost 4 times the output power of a single amplifier. Since each speaker wire is driven and each is at half the supply voltage then an output coupling capacitor is not needed to block the DC.
You can buy circuit-board adapters that accept surface mount ICs and fan their leads out to through-hole pads. It is fairly easy to "drag solder" the surface mount component onto the adapter using an ordinary soldering tip and perhaps a head-mounted magnifier. Google for YouTube videos on how to do this. I did it with a 6-pin PIC that came in an SMD package, but later I ordered the same PIC in a DIP configuration, which made bread-boarding sooo much easier.The problem with Class D amplifiers is, they come in surface mount package whereas I need a through hole package that I can solder with soldering iron. I don't have a blowing gun.
