Does the TDA2030 need negative potential?
rahulb
Mar 14, 2018
45
Hi Everyone,
Do TDA2030 needs negative voltage also?
I mean if I use a rectifier for 12 v, I have to pass +12v and -12v to TDA2030 for proper audio amplification?
thanks
14,313
which shows that it can be used with a single or split rail supply :)
Right, but there is no need for a split supply. It will work properly from a single supply, which is what the op asked about. ;)
rahulb
Mar 14, 2018
45
What's wrong with my circuit then. It is not amplifying at all. amplifierc.png
Audioguru
Sep 24, 2016
3,656
The datasheet for the old obsolete TDA2030 says its minimum supply is 12V when it barely works. Its spec's are with a 28V supply.
Your rectified 12V-0-12V produces +16V which can power the TDA2030 IC then its max output power is shown on a graph as 2.1W into an 8 ohm speaker.
rahulb
Mar 14, 2018
45
But, it is not even outputting 2.1 w. it is outputting somewhere between 0.25 w and 0.5 w max.
14,486
well that's debateable as he asked about a negative supply ;)
It will work so much better on a split rail supply
and also to the OP @rahulb his 12V single rail is just way too low
14,486
As I just finished saying 12V single rail IS NOT suitable :)
Audioguru
Sep 24, 2016
3,656
I told you that if you power the TDA2030 from the rectified 16V that feeds the 12V regulator then the output power will be 2.1W.
5W is only a little louder than 2W.
The datasheet shows 5W into 8 ohms at low distortion when the supply is 22V and is 6W when the supply is 24V.
Why not use a supply of 32V then the output power into 8 ohms at low distortion will be 12W.
Really, linear audio amps are pretty much obsolete.
For $16 I got a class D amp that can produce an honest 25 W into 8 Ohms at 22V. I use it at 16V and get 16 W. It barely gets warm at that level.
And all of this using about 1/2 the power a linear amp would use.
Audioguru
Sep 24, 2016
3,656
On another website today a Bluetooth speaker is using a TDA7492 modern class-D bridged stereo amplifier IC. It produces 25W per channel with low distortion into 8 ohm speakers when its supply is 25V. But it is in a surface-mount 36 pins case. Most Chinese companies sell it already assembled.
rahulb
Mar 14, 2018
45
The problem with Class D amplifiers is, they come in surface mount package whereas I need a through hole package that I can solder with soldering iron. I don't have a blowing gun.
Audioguru
Sep 24, 2016
3,656
The problem with obsolete TDA2030 amplifier ICs is that they are not used anymore and are not made anymore.
14,486
OK guys enough !
Regardless of it the TDA2030 is obsolete or not, the OP HAS one of them. Lets be constructive in helping him get the circuit going !
WHONOES
May 20, 2017
1,242
How big is the transformer you are using i.e. what is its current capability, how many amps. Also, can you measure the static output voltage with respect to 0V.
Just had a proper look at your schematic. Connect the 2030 power supply directly to the rectified and smoothed supply.
Audioguru
Sep 24, 2016
3,656
Maybe Rahulb cannot read the datasheet because it is also not available anymore. The datasheet tells him that his supply voltage is too low.
