Power Relay needed
jngtt
Jul 14, 2016
15
Hi guys,
I have a problem which i need to make a relay which turns on (close the circuit) to a LED when the VDC is over 1.5 VDC.
When the voltage falls below 1.5 VDC, it turns off the LED. The max VDC that will be going though the circuit will be 28VDC.
Please let me know if there are any relays that does this or is there a way to program a micro controllers to handle it.
Thank you very much guys.
Alec_t
Jul 7, 2015
3,820
Welcome to EP!
Depending on the LED spec, it may be easier/cheaper to use a transistor instead of a relay to turn on the LED.
How accurate does the '1.5V' really need to be?
It would be very simple to use a transistor plus diode to have a 1.2V (approximately) threshold instead of 1.5V.
jngtt
Jul 14, 2016
15
Welcome to EP!
It would be very simple to use a transistor plus diode to have a 1.2V threshold instead of 1.5V.
It needs to be on 1.5 VDC and below to turn off the LED
Alec_t
Jul 7, 2015
3,820
How much tolerance on the 1.5V? 10%? 1%? 0.001%? ......
What is the LED spec?
jngtt
Jul 14, 2016
15
For the tolerance, I would like it to be as low as possible,
The LED specs have not been picked out yet but I will be looking for one that can withstand 28VDC.
Most LED's need at least 1.5v to turn on.(1.7v standard red LED)
Are you powering the drive to the LED from another supply?
Alec_t
Jul 7, 2015
3,820
Why?
That will require at least a precision voltage reference and a precision comparator. VDC would need to be extremely stable, so that LED current doesn't pull it down, otherwise the circuit would go into oscillation. What is your budget for this?
jngtt
Jul 14, 2016
15
No I will be just using the same power.
Why?
Well the budget is around 150 US dollars. Its for an aviation testing circuit.
jngtt
Jul 14, 2016
15
All I am trying to do is to turn a LED on when the voltage is above 1.5VDC. When it falls on 1.5 VDC and lower, the LED will turn off.
The range of the Voltage will be 0 to 28 VDC.
The reason I need the tolerance to be low as possible, is to be accurate as much as possible.
Alec_t
Jul 7, 2015
3,820
That's obviously desirable, but the method used will depend on the allowable tolerance. Give us a number to work with.
Most LEDs will not light up at 1.5V. What color is the LED? Hopefully red, they are the lowest, but typically they still need about 1.8 to 2.0V. You might need something like a Joule Thief to get it to run reliably at 1.5V.
Then you have the problem of comparing the voltage. A standard comparator will not operate at 1.5V.
Is it a strict requirement that the LED and associated circuitry run off the input voltage? Everything is a lot simpler if it does not.
jngtt
Jul 14, 2016
15
Yes, Because there are no other power source. In other words, it is just an indicator conditioning circuitry.
All i need is when the voltage drops 1.5 VDC, the LED turns off. That's it. But like you mention, some leds do not work under 1.5 VDC, but can they handle 28 VDC?
Sorry, I am a bit new to circuits.
Sunnysky
Jul 15, 2016
577
When you define that it must be self powered and the lack of indication implies power failure, and you want high accuracy, with LED indication at a voltage above 1.5V which is below where LEDs turn on bright, you must realize you have defined a very restrictive set of requirements.
For $150 you can include a battery yes?
Then the solution is a trivial, LDO+ comparator to drive any LED and costs $5
I hope the penny drops for the Op soon Bob.o_O
Alec_t
Jul 7, 2015
3,820
If the tester is intended as a portable one, not permanently connected to the DUT, do yourself a favour and spend some of your budget on a PP3 battery. Then you can build this for ~5$ :) :-
If you insist on having no external voltage source then, as mentioned above, a Joule thief circuit could be used to derive a supply of several volts for powering a tester.
jngtt
Jul 14, 2016
15
Your circuit can work but would love to have the circuit without additional battery so it can become maintenance free.
I have inserted a diagram on what i want to do and in the box were the note is, i would like to have the relay or transistor to do the switching off when it falls below 1.5VDC.
Sorry i didnt add the image earlier.
It should be simple right?
John
Sunnysky
Jul 15, 2016
577
John
You dont seem to understand what I've told you.
An Ultrabright Red LED needs 2V, (the old GaAs dim red 1.8)
This means it goes out below 1.8V or barely visible
Your circuit exceeds the recommended 20mA above 22V
Do you understand Ohm's Law?
jngtt
Jul 14, 2016
15
But i need it to go out at 1.5V not 1.8V
