power requirements for xmas lights
Marnok
Dec 7, 2012
3
I am trying to fix up some xmas lights to run on battery instead of mains. I got 24v of battery together, cut the wires into the controller box so I have some bare ends to feed in to, but when I touch the wire ends together the lights just flash once then off.
OK the back of the "Flasher Unit" says
24v - 50Hz, 1.0A
The 50Hz thing makes me, (electronics skill level: Vandal) think that the supply requires AC not DC.
Is that a reasonable thing to think? and if so, I suspect inside the box this is being converted to DC, as I would be surprised if the LEDs themselves were AC. So, I might be able to solder my batteries in to a different point if I crack the case on the flasher unit?
duke37
Jan 9, 2011
5,364
As you say, LEDs need DC, they also need a current controlled supply, not voltage controlled.
An easy way of controlling current in an AC circuit is to place a capacitor in series. If this is followed by a rectifier, then that is all the necessary circuit.
If you go to a DC supply you will need some way of controlling current. This can be done with a (hot) resistor or with a special constant current circuit
Marnok
Dec 7, 2012
3
Thanks, I've opened the box and the inputs are labelled AC, I think I can see where this is converted to DC and all I need do is connect my batteries and cut the converter out, should work... in theory.
Marnok
Dec 7, 2012
3
Well, due to general fail, I now see there is a connection between one of the AC in lines and the IC (via a resitor) which I am guessing wildly was used for timing by the IC.
