Power supply for LED strand
Buddy919
Oct 4, 2023
Too old to be considered "new" at anything, but have no experience or understanding of electronics.
I built an oak cabinet and put in some LED shelf lighting strips. Lights are listed using 8 watts and run on a 12v dc adapter. They came in a strip of 600 lights that was cuttable to length.
I still have several feet of lights left over. Last week, our leaf blower needed replacing. New ones come with batteries and chargers. So now, I'm just wondering if I can use my old battery/charger (2.0 AH, 20v) to power up those extra lights. I've taken a single LED and lit it up with a 9v battery, but I'm not sure if I plug in too many of the lights I'll kill the battery, or will too few lights cause the battery to burn out the string, or some other god-awful thing might happen.
The lights and battery seem awfully convenient, since they are already available and paid-for. It seems a waste if I can't find another use for them.
I do know there are formulas to determine how much power you might need, but without understanding it I am at a loss to figure it out.
Can someone please let me know if this can work (or if it's dangerous!), and if so, how many lights would I be able to turn on?
Also, if someone has found other uses for these large tool batteries, I would love to hear the ideas. Thank you.
kellys_eye
Jun 25, 2010
6,512
Your light strip requires 12V to work regardless of the length of the strip that may be cut from the original. Running off-cuts using 9V will work but with reduced light output.
All you can do by powering 'too many' LEDs is flatten the battery quicker - just recharge it! You can't do any damage by running too few LED's - the battery will just last longer.
danadak
Feb 19, 2021
1,103
The 20V charger, thats controlled for charging a battery, so might have shutoff
automatically or not even start up because it thinks battery pack (when used as a
battery charger) is too low a V (in this case 12V) and no longer usable battery.
How many strips do you have to run ? Is it 8W for the total 600 leds ?
I would think easiest way just use a 20W 12V brick (20W to give some margin) would
be easiest way. Current you need is P = I x V or I = P / V = 8W / 12V = ~ 3/4 Amp X the
number strips you have to power.
So buy a brick and use some margin. Example if you have 4 strips, then thats 32W,
but a brick is ~ 80% efficient, so thats 32 W / .8 = 40W
Using a brick they usually have thermal and short circuit protection.
Or use
You could possibly use a buck regulator at the output of the charger, but again the buck charger combo
might not power up right, bit of a crap shoot.
You need to answer how many 8W strips you need to power.
Computing P, V, I in DC circuits roughly :
Regards, Dana.
