Power supply help
am.steen
Jul 10, 2023
41
I have this small power supply that output 12v and 38v that only ic is damaged and I do not know its number please help
Delta Prime
Jul 29, 2020
2,993
Make? model number?
The information given on the PCB board itself tells me what store it came from.
U1 there are numbers and letters etched into it but I can't see from the angle you took the photo so you're going to have to put it under a light and wiggle it around too you can see the etched information on the chip.
There are other concerns as well for example.
am.steen
Jul 10, 2023
41
These under board connections I do it my self after chip was burned but the original pcb layout I take it from a Chinese web site is similar to this
am.steen
Jul 10, 2023
41
These are the best photos I can get for the burned IC from both sides ...
Delta Prime
Jul 29, 2020
2,993
Thank you for your honesty you're definitely going to heaven but you might practice a little more here on Earth "soldering".
This is constructive criticism; if you were to solder brand new components it would not work as expected.
Thank you for taking the time to take other photos it's more clear but still do you think you could write down the numbers yourself? Thank you.
am.steen
Jul 10, 2023
41
For the burned IC
LN1524. The letter L is not clear. I guess it.
On the other side, p1f24s8114
On board
JSQDY-EMO02AG
SU-8490A
am.steen
Jul 10, 2023
41
I get ca-888 module locally and I install it in my power supply but I do not know where to connect FB as I can not find FB on my board
I need little help to connect the white FB cable as it is not working without it
am.steen
Jul 10, 2023
41
The voltage at red cable and ground should be at least 12v but it measured 9v when disconnect red cable it measured 50v. Do I have to decrease r12 value to have 12v or I have to add FB circuit manually ??
am.steen
Jul 10, 2023
41
I study that link, I am not professional in power supply but I think my board is not PFC. Is it right ??
am.steen
Jul 10, 2023
41
I add FB circuit and it works with c888 module with those issues
1. Runs on load only ( 12v lamp connected to 12v terminals)
2. The 12v terminals measure 11.5v
3. The 38v terminals measure 51v
4. The ac serial lamp is half lighted
Sorry for digram it is hand drawing
Any suggestions??
14,484
This is my ps. Circuit diagram
which is very different to the circuit board you have. It's missing half of the components on your schematic.
Doesnt show the blown IC
Shows a PC817 Opto-coupler that I dont see on the board ?
The transformer secondary windings are not separate 9 as you have shown them) - It's a tapped winding
Again Note .... it's 38 not 28 .... the 3 is very obvious from your first photos
But I now see that the last photo showing the 12V and 38V is from red coloured terminals
This isnt even the same as your board
PLEASE show photos of the output of YOUR board - both sides
