power surged lcd monitor turns on and off continuously
i have a 19 inch lcd monitor from viewsonic. was gone over the weekend
and when i came back it was broken. it was plugged directly into the
wall, not surge protected, and was turned off. but when i turn on now,
it flashes on for a very brief time, less than a sec, and i can see a
clear image, but then turns off, then turns back on and flashes the
image again. this cycle repeats over and over at a cycle of a few
seconds w/ the monitor being mostly off. the power light cycles too
along w/ the image. any suggestions on fixing it?
JW
Usually, when a LCD monitor turns on briefly then shuts off, it is due to
a fault in the inverter board. This is the first one I've seen that keeps
retrying automatically, though. First, I would check the fuses and FETs on
the inverter itself.
there are two boards: power board and one more that has the dvi and vga
ports plugged into it which seems to be more high tech. there is a
fuse on the power boards and it's till in tact.. can't tell which one
is an FET.. seems to be a shame but looks like i'm gonna have to junk
it... thanks for the suggestion.
JW
How did you test it?
is an FET..
3 legged device. Google MOSFET.
Problem could also be one of the tubes. This is most likely a simple
repair. Shame to junk it... You could have it repaired for $75 to $100.
