power trouble
helio905
Mar 31, 2006
17
I build robots in spare time. But this is my first on board pc. The only way I
know to power it is a 12 volt car battery and a 12vdc/110 inverter. I was
apperent that you loose alot of power this way. I know the input to the
main board must be perfect. Any power saving tips?
ante1
Jan 24, 2004
4,136
Hi helio,
For every step you lose energy, this is not the way to go. I would recommend only one step conversion to get the highest possible efficiency. Use two smaller (half the size of the car battery) 12 V deep cycle batterys in series (24 V) and buy a new PSU for the PC. Here is one example for ATX PC:  http://www.zantech.com.au/zantech/power-supply-atx-24v-dc/
I hope I make sense.  ;)
helio905
Mar 31, 2006
17
Thanks for the advice. And yes I noticed even the car battery does not last
long whith the pc and drive motors not to mention all the other loads I am
runing. I wonder though if I do this like you say, if the overcurrent will shut
the pc down every time my robot runs it drive motors. They use alot of
curent. They are powerwheels gearboxes.
ante1
Jan 24, 2004
4,136
If the load peaks is too high for the batterys internal resistance the voltage will drop and the computer might shut down. You should consider larger capacity batterys.
Tony_Stoynov
Dec 20, 2005
197
why you used a standard PC board, why you dont use some industril on board PC. Many of them use only 12 or 12 and 5 V. Something like a Arbor EmCore 615, this is Via based PC. Has a many other company that produce this type of board, they is not very big, used only one power suuply, n some case two, and is mre reliable. The ony one disadvantagem the price is higer :)
ante1
Jan 24, 2004
4,136
Depending on the length of the surges from the motors the PC can be protected from shut downs simply by adding a diode and a capacitor to pick up the slack.
