Powering 5050 RGB led strips
davedobson
Nov 26, 2013
13
Hi there, newbie to electronics generally but am hoping to work on some small projects involving led strips. I had just finished a poker table and used a strip of leds with remote etc and had about 2 feet of led strip left over. Is there anything I can do with these without buying a whole lot of accessories? Am I able to somehow connect them to another power source? (batteries would be ideal) I don't care if they all end up one colour etc. Any help is appreciated! Thanks!
Sunnysky
Jul 15, 2016
577
LED strips with RGB may have a smart chip or not.
If not then they simply string 3 RGB strips in series with 3 R's to 12V and you ground each colour Pin R,G,B or any combination. You may power from a 14V Lipo pack as brightness will increase from ~9V to 14.5V as current drain rises and discharge time reduces.
davedobson
Nov 26, 2013
13
Thx for the reply Sunny. Unfortunately a lot of what you are saying is over my head :)... the strip looks exactly like these:
https://www.google.ca/search?q=rgb+...UICCgB&biw=1461&bih=870#imgrc=LqZUsBcG9iqaOM:
Do I need any special connector to operate these (as I used the one that came with the original package) I'm hoping to connect maybe a 9V battery? Would that power any of these? And I'm not sure how to ground the colours as you mentioned.. thanks!
Sunnysky
Jul 15, 2016
577
9V Alkaline wont last long and these run of 12 V nominal
read again
4 pads
V+ is common to all RGB to bat+
any or all RGB pads to bat-
try to use cordless drill battery 14.5V or 4 x 16850 LiPo cells each 3.6V
