Problem identifying a component value Conext 60 150 MPPT charge controller.
Ron Bailey
Feb 17, 2021
I am trying to replace what I believe to be a Schottky Rectifier.
The black line circling the 4 schottkys is where I am working.
I cannot find any info online, or a schematic for this unit.
I would like to select a suitable replacement.
Thanks for any help
Update:
I removed the suspect component and it seems to work as it should.
My controller boots up and looks normal except it shows no amps or watts coming in from solar.
73's de Edd
Aug 21, 2015
3,730
https://datasheet.octopart.com/10BQ040PBF-Vishay-datasheet-9803539.pdf
Page 2 . . .at end of . . . . THERMAL - MECHANICAL SPECIFICATIONS . . .re the assignmeent of the Vf1 marking code.
Looks like you have 4 green pass transistors and their associative / isolative Surface Mount steering diodes .
If using a DVM's "diode test" mode, with its meager test current being utilized, looks like 400-500 mv might be in order, in considering the upward sliding spec of a more typical 1A and 25-125 deg temp shift in real time operating conditions.
PLUS . . . . . that photo is far too small and of too poor of definition to extract any meaning from it, as well as the omitted other board side.
