Need help identifying problem with Logitech Computer Speakers.
A.Cannella
Oct 7, 2014
Logitech THX Z-2300 Computer Speakers and Subwoofer. I've had them for several years. I was playing music and smelled burning coming from the woofer through the port hole. I unplugged it all left it alone for a while. A few weeks later I checked the fuse (.4A/125v) and noticed it was blown. I tried a new fuse and it blew right away. I've bought a couple new fuses and each gets blown right away. The control pod will not power up anymore. I just noticed that one of the prongs on the back got bent off when we moved not sure if that is causing the control pod not to power up. The control pod wouldn't power up before the prong was bent either. Help! Can't see myself getting rid of these they are awesome and I've had them for a long time.1627_2430.jpg 0610205179-colunas-logitech-z-2300-thx-200-watts-rms.jpg
A.Cannella
Oct 7, 2014
10665758_10152752511175993_1167380691589172610_n.jpg 1966670_10152752535325993_927097724986219197_n.jpg 10698670_10152752533510993_1655729237151998818_n.jpg
The broken prong is the top right one. The burning smell and the blowing fuses happened before this got broken.
14,487
undo that clamp bar across the devices screwed to the heatsink and tell us what those devices are
you may find that one or more of them has a puncture hole in the front of them
do a sharp close up pic of the transformer
and also of those 2 devices in the yellow sealer below those 2 big capacitors
which fuse was blowing ? ( that is ... where is the fuse located that was blowing ?)
KrisBlueNZ
Sadly passed away in 2015
Nov 28, 2011
8,393
And show us closeups of both sides of the board in the area of the D-15 connector you want to replace.
