Problem of model when simulating under spectre
V
vivian
I am doing simulation using spectre. It keeps giving me the following
errors:
Syntax error in model statement,
Syntax error in specification of `dvt0w',
Syntax error in specification of `dsub'.
Syntax error in specification of `pbsw'.
Syntax error in .model statement.
I am using Tsmc25 model. And it works well in spice simulation. What
is the possible reason of this error?
Thank you in advance!
K
Kevin Aylward
errors:
Post the whole .model text. we cant tell you what the error in the model
is without seeing the model!!!
Kevin Aylward
[email protected]
http://www.anasoft.co.uk
SuperSpice, a very affordable Mixed-Mode
Windows Simulator with Schematic Capture,
Waveform Display, FFT's and Filter Design.
V
vivian
Thank you for your reply. Here is the model I use.
* LOT: n94s WAF: 08
* Temperature_parameters=Default
MODEL NMOS nmos LEVEL = 11 \
TYPE = NMOS \
VERSION = 3.2.2 TNOM = 27 TOX = 5.8E-9 \
XJ = 1E-7 NCH = 2.3549E17 VTH0 = 0.4308936 \
K1 = 0.3519429 K2 = 0.0298493 K3 = 1E-3 \
K3B = 0.0592323 W0 = 1E-5 NLX =1.465901E-7
DVT0W = 0 DVT1W = 0 DVT2W = 0 \
DVT0 = 0.0183405 DVT1 = 4.897584E-3 DVT2 = -0.0252658
U0 = 455.3033362 UA = 5.223592E-10 UB=1.104713E-18 \
UC = 3.287888E-11 VSAT = 1.050993E5 A0 = 1.2318623 \
AGS = 0.3043334 B0 = 6.67749E-8 B1 = 5E-6 \
KETA = 8.518046E-4 A1 = 0 A2 = 1 \
RDSW = 509.5675851 PRWG = 0.0227558 PRWB = -1E-3 \
WR = 1 WINT = 2.126497E-9 LINT =4.393474E-9
DWG = -3.409033E-9 \
DWB = 2.794842E-9 VOFF = -0.1026054 NFACTOR = 0.1344887 \
CIT = 0 CDSC = 1.527511E-3 CDSCD = 0 \
CDSCB = 0 ETA0 = 3.48737E-3 ETAB = 4.557986E-4
DSUB = 3.045473E-3 PCLM = 1.0446257 PDIBLC1 = 0.1441952 \
PDIBLC2 = 4.513382E-4 PDIBLCB = -2.816756E-5 DROUT = 0.4698725 \
PSCBE1 = 1.761109E10 PSCBE2 = 3.772916E-9 PVAG = 0.0361824 \
DELTA = 0.01 MOBMOD = 1 PRT = 0 \
UTE = -1.5 KT1 = -0.11 KT1L = 0 \
KT2 = 0.022 UA1 = 4.31E-9 UB1 = -7.61E-18 \
UC1 = -5.6E-11 AT = 3.3E4 WL = 0 \
WLN = 1 WW = 0 WWN = 1 \
WWL = 0 LL = 0 LLN = 1 \
LW = 0 LWN = 1 LWL = 0 \
CAPMOD = 2 XPART = 0.4 CGDO = 6.27E-10 \
CGSO = 6.27E-10 CGBO = 0 CJ =1.918655E-3
PB = 0.9784049 MJ = 0.4721729 CJSW =4.441595E-10 \
PBSW = 0.9419636 MJSW = 0.2871118 PVTH0 = 1.342985E-3
PRDSW = -61.8357222 PK2 = -3.140724E-3 WKETA = 7.512693E-4
LKETA = -6.144062E-3
