problem with dsc 1616 power keypad
N
NilsCA
Hi
I'm trying to setup my dsc 1616 system - did the wires, etc.
Now ... if I turn on power the keypad (PK5501) shows the little keypad/
finger symbol on the left and a unset clock to the right (with
blinking colon)
Pressing any key on the keypad makes the clock go away ... it returns
to - - : - - a couple of seconds later.
If I press hash (#) for 2 seconds or so the keypad beeps 3 times and
the little warning symbol lights up on the right (none of the 4
symbols was one before), the little keypad/finger on the left
disappears.
Not typing anything the keypad returns to the state above.
If I type star (*) or hash (#) I get another beep - the latter seems
to return the keypad back into the state above ... it's weird and not
at all what's expected.
I've reset the the console via the bridge between PGM1+Z1 ... no
change.
Anyone know how to unwedge this?
Nils
F
Frank Olson
NilsCA said:
Hi
blinking colon)
disappears.
change.
Nils
All DSC products need to have the clock set when you first power them
up. Enter *6, then your four digit master code, then 1, then the time
(in 24 hour format) hh/mm then the date mm/dd/yy then "#" twice. Read
the freakin' manual. :)
alarman
Mark said:
Yea get someone who knows what they are doing and can read
instructions to work on it
Maybe it IS rocket science after all.
N
NilsCA
Hi Frank
thanks for the reply - yeah, I should have mentioned that I tried that
already.
I press
* 6 1234 1 1212 121207 # #
there's no beeps, no change in display, no acknowledgement at all, no
change to the keypad showing the little program symbol on the left
If I go
hold # (3 short beeps, light goes on, programming symbol goes away)
then it beeps once somewhere during that sequence - light goes off,
programming symbol appears again.
I still get nothing - the keypad keeps on only showing the little prog
system left
I fear there's something not right with the keypad. Any way to hard-
reset it (tried the console as mentioned already)?
Cheers and Thanks for trying
Nils
N
NilsCA
Hmm, have to reply to myself - got some more info
I've managed to unwedge the keypad by
press # (beep) hold (3 beeps)
press 1 (beep) hold (3 beeps)
the programming symbol goes away and the keypad is as I'd expect. Set
the clock, program a zone, test the system (*6 MMMM 4), door chime,
etc. all works
After 10 secs inactivity the panel switches back to showing the clock
and keypad symbol on the left, doesn't take input, no door chime, no
ready symbol.
I've done all factory default resets [993-999] ... anyone have another
good RTFM pointer I'm missing?
Thanks a lot
Nils
Crash Gordon
another boat anchor
Crash Gordon
-------ouch------
<I feel like I'm diagonally parked in a parallel universe>
| Mark Leuck wrote:
| > | >> Hi
| >> keypad/ finger symbol on the left and a unset clock to the right
| >> (with blinking colon)
| >> disappears.
| >> change.
| js
| - The bigger they are, the harder they fall.
| ( Also, the harder they bite, punch, and kick.)
alarman
NilsCA said:
case closed - it was an invalid partition/slot assignment
Mark & alarman, you might want to read up on that one :)
We need to read up because you programmed the keypad with an invalid
partition assignment?
js
alarman
Mark said:
Projection "A defense mechanism in which one attributes to others
one's own unacceptable or unwanted thoughts or/and emotions"
Fat-fingering: <slang>
1. Tinkering with electrical/mechanical devices without the slightest
inkling of what one is doing.
2. Rendering said equipment inoperative through direct action in spite of
gross ignorance.
motley me
etc. all works
ready symbol.
Thanks a lot
Nils
Sounds like you have the keypad set as a global keypad.
Set the address to 11.
It's in the manual
N
NilsCA
yes, that's the trick - thanks for your helpful post motley me
Cheers
Nils
N
NilsCA
Hey alarmman
I'm in a good mood so I'll spell it out for you:
yes, I'm a newbie who had a question - I got friendly help to try to
diagnose it (in the end I found the solution myself actually)
you on the other hand don't like to help newbies, as a matter of fact
you don't keep it for yourself but make that perfectly clear with your
snotty answer; apparently you think you're an "expert of some sorts"
while your diagnosis ends up being wrong ... wow
That leaves me as a newbie and you as a pretty unfriendly person who
doesn't know it all even though you're full of yourself ... maybe you
can still lighten up a bit, help some old lady across the street, make
some friends, sharpen your skills - good luck
Cheers
Nils
N
NilsCA
sorry, another follow up :)
I mixed you up - you didn't provide any solution at all actually. So
please scratch
you can keep your expert hat and don't read up. Only your unhelpful,
snotty attitude to work on ;)
Cheers
Nils
alarman
NilsCA said:
Hey alarmman
Cheers
Nils
Hey, dumbass
The fact remains you don't know what the **** you're doing, didn't RTFM, and
misprogrammed the system. You gonna deny that now?
Then, you told me that I needed to read up. What a laugh.
I'm willing to help anyone who isn't so lazy that they can't read the
instructions. You are typical of a lot of the losers who blow in here and
want your hand held, then get mad when you're taken to task for being a
complete idiot. Software/network/computer guy...right.
alarman
please scratch
Cheers
Nils
Still not reading before you act I see. Maybe you need to work on that.
