V
Victor Roberts
- Jan 1, 1970
- 0
Ahh! Sounds like someone who can answer a long standing question.
Background:
I understand the older switch start system. You need something like 500
volts to start the tube discharge, the ballast inductance keeps the arc
going (My mental model).
Only instant start lamps need voltages near 500 volts. Rapid Start and
Switch Start lamps have heated electrodes and can start with much
lower voltages. I believe the starting voltage for a 4-foor T12 rapid
start lamps is about 230 volts. 2-foot switch start lamps can start on
120 volt circuits with no inductive kick.
The role of the ballast is to LIMIT the current drawn by the lamp. The
arc will keep going quite well without any ballast. In fact, so well
it will burn out in a fraction of a second
So how does the rapid start get started? and what's the interchangeability
between switch start and rapid start fixtures and bulbs?
On a traditional rapid start system the electrode voltage and lamp
voltage are applied at the same time. The lamp voltage is not high
enough to start the lamp while the electrodes are cold. Once the
electrodes heat to operating temperature the lamp starts.
Switch start lamps have higher resistance electrodes than normal rapid
start lamps and can only be used on special rapid start ballasts
designed for these higher resistance electrodes.
