problem with op amp positive and negative feed back at a time?
chaitanya2k6er
Dec 9, 2010
3
hi!!
I got stuck up with the op amp circuit which has both the positive and negative feed backs? What is the use of using op amp with both feed backs at a time? How to analyze the circuit? Please suggest me the solution with the required formulas.
Thank u..
Do you want to post a link to the schematic?
And why do you want the circuit explained (it may help us in formulating a suitable reply)?
chaitanya2k6er
Dec 9, 2010
3
i have attached the circuits related to this.
no specific reason, i want to implement the circuit for some application.
  • default.pdf
Laplace
Apr 4, 2010
1,252
The basic technique for analyzing an op-amp circuit is to calculate the voltage at the (-) input to the op-amp as a function of the output and/or input voltage. Then do the same for the (+) input. Set these two expressions equal to each other, V(-)=V(+), then crank the algebra to get the output voltage as a function of the input voltage. So if I did the algebra right, the answer is Vo = V1(R1R4+R2R4)/(R2R4-R1R3).
Laplace
Apr 4, 2010
1,252
Just write the node equations at the op-amp inputs, then solve for the output voltage as a function of the input voltage. See attachment.
