Problem with Visonic K9-80
I purchased and installed the Visonic K9-80 based on recommendations
that I found in this forum. However, I am having problems with it in
that it appears to not go off when it should. I can often walk right
down the middle of the room right across it's field of view and it
will not go off. Other times it will. Once, I had a person and 2 dogs
walk in front of the detector and it didn't go off. I can not find any
pattern for when it detects me and when it does not. I believe the
coverage left to right is fine because when I'm higher up on the
stairs all the way to the side of the room it always picks me up. The
detector is mounted 8 feet off the ground (floor to bottom of
detector) in the corner of the room. The sensitivity is set to 2
(middle). I have the vertical adjustment set to 8 feet. The only thing
that comes to mind is that somehow the verticle adjustment is wrong
and it thinks that I am below 3 feet and is ignoring me. But I did
adjust the verticle adjustment as outlined in the manual. Any
suggestions or could this just be a dud?
Thanks!
Crash Gordon
Sounds like it's working fine.
Leave the room empty for 5 or so minutes (no people, no animals) then walk
test it.
PIRs are generally less sensitive when you move directly towards it, rather
than across the detection fields.
| Hello,
| Thanks!
Petem
Thanks!
Hi what you dont seem to know is that this pir will not detect motion all
the time,this is to preserve battery life...
the detector will go in a sleep mode after detecting a motion for a small
period of time usualy for 3 to 5 minute ,during that period you will notice
no reaction from the pir...
Doug
I believe the K980 is hardwired not wireless. It doesn't have a battery or a
sleep mode.
Doug
Robert L Bass
How have you set switch SW-1? If it is "Off" the detector will respond to the first motion it detects. If it's set to "On" the
detector will only respond to two sequential motion events. This is to prevent false alarms though it can sometimes render the
detector disabled if the location is wrong for it.
Double check and try it again. If you still have trouble it might just be a bad unit. That detector is usually reliable but it's
possible you got a bad one. If so, your dealer should replace it for you. If they won't, give me a call and I'll arrange for
warranty service. There's no charge for that. You just have to send it in.
Regards,
Robert L Bass
Bass Home Electronics
941-925-8650
4883 Fallcrest Circle
Sarasota · Florida · 34233
http://www.bassburglaralarms.com
Doug
If its a wireless version shouldn't the subject be "Problem with Visonic
K9-80W" ?
Doug
Crash Gordon
petem is in a sleep mode :)
k980 is hardwired for sure
a
| sleep mode.
| Doug
all
small
| > notice no reaction from the pir...
Crash Gordon
Welp it is pronounced that way
| > K9-80W" ?
| > Doug
| Then he'd still be wrong since there is no dash between 9 and 80, it's
times
| like these where the rocket science knowledge kicks in
| > | > > They have a wireless version, the K-980W and it has a 2-minute sleep
| > > window
battery
| > >> or
| > > a
| > >> sleep mode.
| > >> Doug
motion
| > > all
| > > small
will
It's not the wireless version. Just the regular old hard-wired K980.
The SW-1 is set to 2 because I do have animals and I'm hoping to
prevent false alarms. I guess I'll try adjusting the angle or swapping
it with another unit and see if it make a difference. Thanks for your
feedback.
Crash Gordon
What is the pir looking at when it is at rest? If it's looking at a bare hot
wall (like heated from sun) it might slow down the response.
| feedback.
Petem
my fault, most visonic i've serviced were wireless...
so for me visonic mean wireless...
Crash Gordon
New Mexico? or new Mexico...but me accent is prbly more like New Yawk.
| Well thats due to your New Mexico accent, we say it different in Texas
| Visonic
| > | > K9-80W" ?
| > | > Doug
| > times
sleep
| > | > > window
| > battery
| > | > >> or
| > | > > a
| > | > >> sleep mode.
| > | > >> Doug
| > motion
| > | > > all
for
| a
| > | > > small
| > will
Robert L Bass
I installed a zillion Fox and Coral hardwired motions
Uh-huh.
