problem with WinPIC & ICProg with PICEX1000 programmer
Dr Mitch
I can't seem to reprogram my pics. Some of my pics, I can program. But
others, I get Verify errors and program failed... I'm only using 16F88
and 16F688 pics, some of each don't verify. Did I maybe... write/read
protect the chip somehow? If so, How do I fix it?
Thanks!
John Popelish
Thanks!
Are you, by any chance, using a PicStart Plus programmer?
John Popelish
Sorry, I don't have experience with that. I found a design
weakness in the PicStart Plus that made its operation
unstable in a way that sounded like what you are describing.
It has a boost converter to create the program voltage,
for the PIC, that contaminated the 5 volt supply with
voltage spikes. In that case, replacing the storage caps
before and after the converter with low ESR types got the
spikes under control and all the symptoms cleared.
You might try paralleling some additional capacitance (even
just across the supply pins of the chip being programmed in
the ZIF socket) across your supply lines to see if the same
kind of thing is works for you.
Jon Slaughter
Make sure there are no errors. I know I've had similar issues and its
because winpic doesn't have the proper files for those pics. It will say
something about not having the proper initialization sequence or
something(actually I forgot). Its in the messages tab and it says it when
you try and start the write processes.
The point being even though it lets you select the pic sometimes it doesn't
have the ability to program it. Not sure why.
