Problem with writing eeprom memory
Novacicm
Aug 12, 2017
3
I am trying to write atmel at28c256 on breadboard so I tied all address lines to ground, and all I/O lines also tied to ground. I untie I/O lines for reading, tie 'WE to high, 'CE to low, and 'OE to low for reading. I am reading all ones at I/O ports, no matter what address. So, when I try to write this eeprom I put 'OE high and with 'WE line I touch to ground so that should write stuff to memory but it does not, all I/O ports were connected. I also made small RC circuit with button on WE but that also does not work. Any toughts?
Novacicm
Aug 12, 2017
3
kellys_eye
Jun 25, 2010
6,512
You will - a standard 'unprogrammed' EPROM is usually set to FF (all locations).
Novacicm
Aug 12, 2017
3
Yeah I know that but also when I try to write memory to some pattern of 8bits I am always getting FF all ones in memory.
kellys_eye
Jun 25, 2010
6,512
If you have tied all address and data lines to zero the programming function (assuming you get the proper 'low' pulse applied) will write whatever you have set on the data lines to the address you have on the data lines.
Assuming all lines are zero then the programming pules should write 00 to address 0000.
Have you got pull-up resistors on address/data lines?
Have you got proper supply line decoupling in place?
Have you got a de-bounced program signal?
