Pspice Mosfet Headaches
H
Hammy
I've been trying to use Fairchild's RFP30N06LE (logic level n-channel
Mosfet) Pspice model.
The datasheet with the model is here:
http://www.fairchildsemi.com/ds/RF/RFP30N06LE.pdf
The model fails to converge in a simple switching a resistive load
test cct, let alone the cct I want to use it in. I have tried all
typical approaches to resolve this such as relaxing the tolerances,
GMIN stepping, increasing ITL4 and skipping DC bias point. I've also
tried other mosfet models based on this same subcircuit and none of
them converge like the RF1S23N06LE and RF1S30N06LE. Placing the
FDN359AN in the exact same cct the cct converges, so I know there is
nothing wrong with the test cct.
I'm hoping someone knowledgeable in FET modeling could take a look at
the model and provide some insight. The model text is below as well.
Thank you.
PSPICE Electrical Model
SUBCKT RFP30N06LE 2 1 3; rev 6/2/93
CA 12 8 1 3.34e-9
CB 15 14 3.44e-9
CIN 6 8 0 1.343e-9
DBODY 7 5 DBDMOD
DBREAK 5 11 DBKMOD
DESD1 91 9 DESD1MOD
DESD2 91 7 DESD2MOD
DPLCAP 10 5 DPLCAPMOD
EBREAK 11 7 17 18 75.39
EDS 14 8 5 8 1
EGS 13 8 6 8 1
ESG 6 10 6 8 1
EVTO 20 6 18 8 1
IT 8 17 1
LDRAIN 2 5 1e-9
LGATE 1 9 7.22e-9
LSOURCE 3 7 6.31e-9
MOS1 16 6 8 8 MOSMOD M = 0.99
MOS2 16 21 8 8 MOSMOD M = 0.01
RBREAK 17 18 RBKMOD 1
RDRAIN 50 16 RDSMOD 11.86e-3
RGATE 9 20 2.52
RIN 6 8 1e9
RSCL1 5 51 RSLVCMOD 1e-6
RSCL2 5 50 1e3
RSOURCE 8 7 RDSMOD 26.6e-3
RVTO 18 19 RVTOMOD 1
S1A 6 12 13 8 S1AMOD
S1B 13 12 13 8 S1BMOD
S2A 6 15 14 13 S2AMOD
S2B 13 15 14 13 S2BMOD
VBAT 8 19 DC 1
VTO 21 6 0.5
ESCL 51 50 VALUE = {(V(5,51)/ABS(V(5,51)))*(PWR(V(5,51)*1e6/89,7))
..MODEL DBDMOD D (IS = 3.80e-13 RS = 1.12e-2 TRS1 = 1.61e-3 TRS2 =
6.08e-6 CJO = 1.05e-9 TT = 3.84e-8)
..MODEL DBKMOD D (RS = 1.82e-1 TRS1 = 7.50e-3 TRS2 = -4.0e-5)
..MODEL DESD1MOD D (BV = 13.54 TBV1 = 0 TBV2 = 0 RS = 45.5 TRS1 = 0
TRS2 = 0)
..MODEL DESD2MOD D (BV = 11.46 TBV1 = -7.576e-4 TBV2 = -3.0e-6 RS = 0
TRS1 = 0 TRS2 = 0)
..MODEL DPLCAPMOD D (CJO = 0.591e-9 IS = 1e-30 N = 10)
..MODEL MOSMOD NMOS (VTO = 1.94 KP = 139.2 IS = 1e-30 N = 10 TOX = 1 L
= 1u W = 1u)
..MODEL RBKMOD RES (TC1 = 1.07e-3 TC2 = -3.03e-7)
..MODEL RDSMOD RES (TC1 = 5.38e-3 TC2 = 1.64e-5)
..MODEL RSLVCMOD RES (TC1 = 1.75e-3 TC2 = 3.90e-6)
..MODEL RVTOMOD RES (TC1 = -2.15e-3 TC2 = -5.43e-6)
..MODEL S1AMOD VSWITCH (RON = 1e-5 ROFF = 0.1 VON = -4.05 VOFF = -1.5)
..MODEL S1BMOD VSWITCH (RON = 1e-5 ROFF = 0.1 VON = -1.5 VOFF = -4.05)
..MODEL S2AMOD VSWITCH (RON = 1e-5 ROFF = 0.1 VON = -2.2 VOFF = 2.8)
..MODEL S2BMOD VSWITCH (RON = 1e-5 ROFF = 0.1 VON = 2.8 VOFF = -2.2)
..ENDS
Jim Thompson
That's not a model, that's an abortion, with all those
voltage-controlled switches. Does the FDN359AN have switches in its
subcircuit?
Thank you.
CA 12 8 1 3.34e-9
CB 15 14 3.44e-9
CIN 6 8 0 1.343e-9
[snip]
.ENDS
...Jim Thompson
H
Hammy
subcircuit?
...Jim Thompson
Hi Jim:
Thanks for your response. Regarding your question I don't see any
VCS's in the FDN359AN. This is a more recent model made in 2002
according to the text.
This is the FDN359AN
..SUBCKT FDN359AN 20 10 30 50
*20=DRAIN 10=GATE 30=SOURCE 50=VTEMP
Rg 10 11x 1
Rdu 12x 1 1u
M1 2 1 4x 4x DMOS L=1u W=1u
..MODEL DMOS NMOS(VTO=1.9 KP=2.25E+1
+THETA=.1 VMAX=0.8E5 LEVEL=3)
Cgs 1 5x 420p
Rd 20 4 1.5E-2
Dds 5x 4 DDS
..MODEL DDS D(M=3.55E-1 VJ=6.33E-1 CJO=226p)
Dbody 5x 20 DBODY
..MODEL DBODY D(IS=4.96E-12 N=1.127089 RS=.001349 TT=12.63n)
Ra 4 2 1.5E-2
Rs 5x 5 0.5m
Ls 5 30 0.5n
M2 1 8 6 6 INTER
E2 8 6 4 1 2
..MODEL INTER NMOS(VTO=0 KP=10 LEVEL=1)
Cgdmax 7 4 260p
Rcgd 7 4 10meg
Dgd 6 4 DGD
Rdgd 6 4 10meg
..MODEL DGD D(M=7.3E-2 VJ=3.11E-1 CJO=260p)
M3 7 9 1 1 INTER
E3 9 1 4 1 -2
*ZX SECTION
EOUT 4x 6x poly(2) (1x,0) (3x,0) 0 0 0 0 1
FCOPY 0 3x VSENSE 1
RIN 1x 0 1G
VSENSE 6x 5x 0
RREF 3x 0 10m
*TEMP SECTION
ED 101 0 VALUE {V(50,100)}
VAMB 100 0 25
EKP 1x 0 101 0 .0195
*VTO TEMP SECTION
EVTO 102 0 101 0 .002
EVT 12x 11x 102 0 1
*DIODE THEMO BREAKDOWN SECTION
EBL VB1 VB2 101 0 .08
VBLK VB2 0 30
D 20 DB1 DBLK
..MODEL DBLK D(IS=1E-14 CJO=.1p RS=.1)
EDB DB1 0 VB1 0 1
..ENDS FDN359AN
*FDN359AN (Rev.A1) 5/15/02 **ST
This was my original choice for what I'm building, and then I got 20
RFP30N06LE for a good price (free) .The RFP30N06LE is overkill for
what I'm doing but easier to work with in a T0-220 packages, versus
the microscopic SOT-23 of the FDN359AN.
I'm sure I can find other uses for RFP30N06LE which is why I'm
interested in the model.
H
Helmut Sennewald
Thank you.
Hello Hammy,
I have tried to run the subcircuit and got error messages.
How have you solved the the two erros in the subcircuit
regarding the three pins of the capacitors?
CA 12 8 1 3.34e-9
CA 12 8 3.34e-9
CIN 6 8 0 1.343e-9
CIN 6 8 1.343e-9
One more change.
..SUBCKT RFP30N06LE 2 1 3
I have tested the "repaired" model with LTspice and PSPICE demo 10.5.
My test circuit has worked in both simulators.
Where is your netlist?
H
Hammy
Hello Hammy,
CA 12 8 3.34e-9
CIN 6 8 1.343e-9
One more change.
Hi Helmut:
Thanks for your assistance. I did the corrections you suggested (I'm
using OrCAD demo 10.5 to), but I still get convergence problems. I
also get several errors in my output file.
This is my test circuit netlist.
* source FRFTR
R_R8 N81164 N81004 2
V_V4 N81004 0 44
X_U1 N81164 N80914 0 RFP30N06LE/HA
R_R12 0 N80914 22k
V_V5 N81706 0
+PULSE 0 5 0 20n 20n 3.82u 26u
R_R14 N81706 N80914 22
This is my output file section with errors.
ERROR -- End of expression not seen
TRS2 = 0)
TRS1 = 0 TRS2 = 0)
..MODEL MOSMOD NMOS (VTO = 1.94 KP = 139.2 IS = 1e-30 N = 10 TOX = 1 L=
1u W = 1u)
..ENDS
H
Hammy
Hi Helmut:
A correction to my netlist, for this line:
Should be just:
Thanks for any assistance.
H
Helmut Sennewald
Hammy said:
Hi Helmut:
* source FRFTR
V_V4 N81004 0 44
R_R12 0 N80914 22k
V_V5 N81706 0
Hello Hammy,
And here is the working example.
You have overlooked the broken lines. The SPICE syntax
requires a "+" character in the first column for multiline SPICE-lines.
May I mention that I got with two mouse clicks the average power
dissipation of the MOSFET with LTspice. It's 4.86Watt in your example.
Best regards,
Helmut
Netlist "RFP30N06E_test2.cir"
* RFP30N06LE_test2.asc
XM1 DRAIN GATE 0 RFP30N06LE
V1 VG 0 PULSE 0 5 0 20n 20n 3.82u 26u
V2 V44 0 44
RL V44 DRAIN 2
RG GATE 0 22k
RS VG GATE 22
..include RFP30N06LE.lib
* .dc V1 0 4 10m
..tran 0 100u 0 1u
..probe
..end
Library file "RFP30N06LE.lib"
Hopefully the lines are short enough for your news reader.
* Fairchild
* PSPICE Electrical Model
*; rev 6/2/93
*CA 12 8 1 3.34e-9
CA 12 8 3.34e-9
CB 15 14 3.44e-9
*CIN 6 8 0 1.343e-9
CIN 6 8 1.343e-9
DBODY 7 5 DBDMOD
DBREAK 5 11 DBKMOD
DESD1 91 9 DESD1MOD
DESD2 91 7 DESD2MOD
EDS 14 8 5 8 1
EGS 13 8 6 8 1
ESG 6 10 6 8 1
EVTO 20 6 18 8 1
IT 8 17 1
LDRAIN 2 5 1e-9
LGATE 1 9 7.22e-9
LSOURCE 3 7 6.31e-9
RGATE 9 20 2.52
RIN 6 8 1e9
RSCL2 5 50 1e3
VBAT 8 19 DC 1
VTO 21 6 0.5
ESCL 51 50 VALUE = {(V(5,51)/ABS(V(5,51)))*(PWR(V(5,51)*1e6/89,7))}
+ TRS2 = 6.08e-6 CJO = 1.05e-9 TT = 3.84e-8)
+ TRS1 = 0 TRS2 = 0)
+ TBV2 = -3.0e-6 RS = 0 TRS1 = 0 TRS2 = 0)
+ N = 10 TOX = 1 L = 1u W = 1u)
..ENDS
* NOTE: For further discussion of the PSPICE model,
* consult A New PSPICE Sub-Circuit for the Power MOSFET
* Featuring Global Temperature Options;
* IEEE Power Electronics Specialist Conference Records 1991.
H
Hammy
Hello Hammy,
Best regards,
Helmut
V2 V44 0 44
RL V44 DRAIN 2
RG GATE 0 22k
RS VG GATE 22
* .dc V1 0 4 10m
.tran 0 100u 0 1u
.probe
.end
* Fairchild
*; rev 6/2/93
*CA 12 8 1 3.34e-9
CA 12 8 3.34e-9
CB 15 14 3.44e-9
*CIN 6 8 0 1.343e-9
CIN 6 8 1.343e-9
DBODY 7 5 DBDMOD
DBREAK 5 11 DBKMOD
DESD1 91 9 DESD1MOD
DESD2 91 7 DESD2MOD
EDS 14 8 5 8 1
EGS 13 8 6 8 1
ESG 6 10 6 8 1
EVTO 20 6 18 8 1
IT 8 17 1
LDRAIN 2 5 1e-9
LGATE 1 9 7.22e-9
LSOURCE 3 7 6.31e-9
RGATE 9 20 2.52
RIN 6 8 1e9
RSCL2 5 50 1e3
VBAT 8 19 DC 1
VTO 21 6 0.5
.ENDS
Hi Helmut:
Thank you for your patience. The problem still persists.
I tried to run your netlist and got the following error:
ERROR -- Less than 2 connections at node DRAIN
I then copied your model text with the corrections over the existing
model txt. This took care of all the syntax errors (or at least Pspice
isn't reporting them).The output file is below. The same test cct I
posted earlier.
ERROR -- Convergence problem in transient analysis at Time = 185.5E-09
Time step = 2.028E-15, minimum allowable step size =
4.000E-15
These voltages failed to converge:
V(X_U1.12) = 3.091V \ 3.189V
V(X_U1.8) = 606.39mV \ 705.10mV
V(X_U1.15) = 3.090V \ 3.189V
V(X_U1.14) = 1.744V \ 1.843V
V(X_U1.6) = 3.091V \ 3.189V
V(X_U1.7) = 42.26mV \ 140.97mV
V(X_U1.5) = 1.744V \ 1.843V
V(X_U1.11) = 75.43V \ 75.53V
V(X_U1.91) = 189.52mV \ 288.23mV
V(X_U1.9) = 3.286V \ 3.384V
V(X_U1.10) = 606.39mV \ 705.10mV
V(X_U1.17) = 1.606V \ 1.705V
V(X_U1.18) = 606.39mV \ 705.10mV
V(X_U1.13) = 3.091V \ 3.189V
V(X_U1.20) = 3.090V \ 3.189V
V(X_U1.16) = 1.495V \ 1.594V
V(X_U1.21) = 3.591V \ 3.689V
V(X_U1.50) = 1.746V \ 1.844V
V(X_U1.51) = 1.744V \ 1.843V
V(X_U1.19) = -393.61mV \ -294.90mV
These devices failed to converge:
X_U1.ESCL
ERROR -- Discontinuing simulation due to convergence problem
Last node voltages tried were:
NODE VOLTAGE NODE VOLTAGE NODE VOLTAGE NODE VOLTAGE
(N80914) 3.2938 (N81004) 44.0000 (N81706) 5.0000 (X_U1.5)
1.7439
(X_U1.6) 3.0905 (X_U1.7) .0423 (X_U1.8) .6064 (X_U1.9)
3.2855
(N810301) 1.7616 (X_U1.10) .6064
(X_U1.11) 75.4320 (X_U1.12) 3.0905
(X_U1.13) 3.0905 (X_U1.14) 1.7439
(X_U1.15) 3.0904 (X_U1.16) 1.4948
(X_U1.17) 1.6064 (X_U1.18) .6064
(X_U1.19) -.3936 (X_U1.20) 3.0904
(X_U1.21) 3.5905 (X_U1.50) 1.7455
(X_U1.51) 1.7439 (X_U1.91) .1895
**** Interrupt ****
As you may have guessed I'm not exactly an expert on spice.
Could this be the problem "X_U1.ESCL" What exactly does ESCL stand for
on the model schematic the symbol looks like a DC source?
I like LTSpice too but it doesn't have a layout tool.
H
Helmut Sennewald
Hello Hammy,
I have sent my files to your email address. Please try it.
Just open the .cir file with PSPICE-AD and press RUN(->).
Have you changed the default convergence settings?
I recommend you send me your files for a check.
You can tell me a lot about your netlist and library file,
but I only believe that when I can verify this with your files.
Best regards,
Helmut
If you don't simulate the whole board, you have to change
the schematic anyway for PSPICE.
So it's not so far from drawing it again in another tool.
H
Hammy
Hello Hammy,
Best regards,
Helmut
Hi Helmut:
Thanks much for your help it's working!!
I set all simulation settings to there default,and it worked.
You will probably get your email back the email addy with my name is
bogus. Sorry but I'm new to newsgroup posting,and didnt want to get
more "spam". My email address is [email protected] .
Again thanks alot you saved me a lot of time,hopefully I can return
the favour in the future.
K
Kevin Aylward
May I mention that with no mouse clicks I get the average power of any
device in SuperSpice:)
