PSU Live 1A Fuse blown repeatedly
  • Thread starter SeventhPrince七少爷
  • Start date
SeventhPrince七少爷
I have one PSU which the Live 1A Fuse blows repeatedly. I read that
changing the rectifier should solve thisproblem. However after
changing the rectifier, the fuse continues to be blown.
Any advise?
Thanks.
SeventhPrince七少爷
CJT
SeventhPrince七少爷 said:
Any advise?
Thanks.
SeventhPrince七少爷
Find the short.
Bob AZ
Check the capacitor and regulating semiconductors.
Bob AZ
Jim Yanik
CJT said:
Find the short.
Probably a shorted switcher transistor or secondary diode.
He should find a book on how switching power supplies work,or read the
application notes for the UC3842 IC.
James Sweet
Did you test the rectifier or just blindly replace it? If you're not able to
test semiconductors you'll dump a lot of money into this thing trying to get
it going and may well still fail.
Arfa Daily
Any advise?
Thanks.
SeventhPrince???
Surely, the very first question to ask, before any of us can help, is what
type of supply is it - switch mode or linear ? Then the next one has got to
be, is the right fuse type being used ? If the supply has a damned great
transformer in it, and some big smoothers to stick an additional heavy load
on besides the core magnetization current at switch on, then if a ' T '
rated fuse is not being used as the replacement, it may well keep blowing at
switch on.
Arfa
Ä
七少爷Seventh Prince
How do I differentiate between these 2?
switch on.
Yes, correct rating fuse is used. What are 'T' fuse and 'big smoothers' ?
Thanks.
Seventh Prince
Ä
七少爷Seventh Prince
How do I test the rectifies? Thanks
Arfa Daily
Thanks.
Seventh Prince
In all honesty, if you don't know how to tell apart switchers and linears,
don't know how to test a rectifier, don't know what a smoothing cap is, and
are able to determine that the fuse you are fitting is " correctly rated ",
without knowing what a ' T ' spec on a fuse is, then I don't think that you
are ever going to get to the bottom of the problem with or without the
group's help.
Power supplies, particularly switchers, are dangerous, and someone with your
apparent lack of knowledge should not be attempting to work on them, for his
own safety ....
Arfa
James Sweet
It sounds like you've got a lot of homework to do before you try repairing
something, I assume you haven't read the sci.electronics.repair faq?
SeventhPrince七少爷
