PSU repair, found strange cap, need guidance
Enginuitor
Jul 25, 2004
36
I recently stopped by HSC (a local surplus place) and found a big old lab power supply that came from the Lockheed Martin labs in Sacramento. Standard 4-knob controls (coarse/fine on both voltage and current), analog meters. 0-40 VDC @ 0-10 amps! Only problem was, it didn't work. So I managed to talk them down to $25 (from the initial $50 price tag), and took it home to the bench.
Lucky for me, this thing is 80% discretes, plus some common transistors and two very standard IC's. 100% replacable!
There were three components inside which showed heat stress: a 12V zener diode, a 1.5k resistor, and this strange electrolytic capacitor with 4 leads. I went back to HSC and bought higher-wattage replacements for the resistor and the zener, but the capacitor stumped me. They didn't have a single capacitor like it. It's a metal-can type, with glossy plastic ends and transparent shrinkwrap over it. There are two leads coming out of each end; each end has a + and - lead. It's marked "CDE" "UFT 570-75", rated at 570MFD, 75VDC, and 105.oC. There is obvious heat stress around the points where the leads enter the body. and the ends are bulged slightly. Here's where I'm stumped... I brought the cap to one of the guys who ran the store, and he said it was probably two caps in one can, as was a popular strategy a while back. However, when I got back home, both my multimeters and an old-fashioned lightbulb continuity tester indicated that the leads on each end were continuous with each other (meter read 0.00), making it appear to be a single radial cap with the leads going in one end and out the other, perhaps for better power/heat handling. Or perhaps it truly was one of those old-fashioned duplex capacitors, and somehow it has failed in a way that by some twist of fate has caused both ends to become connected?
I would appreciate any help identifying this cap, and designing a suitable setup to take its place. As a last resort, I might just slice this baby open over the acid tub, and see what it looks like inside.
Thanks in advance.
Kevin Weddle
Feb 23, 2004
1,620
Look at the traces. Are the leads going to different places or are they combined on the board, such as ground? A four leaded capacitor does not strike a chord with me.
ante1
Jan 24, 2004
4,136
Greg,
Welcome to this forum.
No schematic I guess?
Have you checked the pcb, where this cap is connected to determine + and
Enginuitor
Jul 25, 2004
36
All four leads go different places. However, because this is an old-fashioned single-sided board (hand-routed traces, etc.), it is possible that they just used this particular capacitor instead of the two-lead variety because it doubled as a convenient set of high-power jumpers. I will take the board out again and look more closely at where all the traces go.
Enginuitor
Jul 25, 2004
36
I'm afraid not. However, if I feel up to it I might draw one out. It would probably take most of the day, but could help a lot with the debugging process.
Any chance of a pic to post of the item?
I'll try...
Enginuitor
Jul 25, 2004
36
That looks like two capacitors rolled into one.
I have confirmed perfect continuity between the two sides, on both leads, with both the multimeter and the "lightbulb" test. Can I reasonably expect that this is a BAD thing, and possibly the cause of my problems?
Kevin Weddle
Feb 23, 2004
1,620
With shorted leads, aren't you shorting the two traces together. If they are supposed to be shorted, then why aren't they. They normally don't short two traces together using a component.
Enginuitor
Jul 25, 2004
36
It's possible it had something to to with the component density and the fact that this is a single-layer hand-routed board (before the days when computers figured it out for you!). From the way the traces are laid out, perhaps they just thought it would be convenient. I am pretty convinced that this is a single cap, though, based on the following:
Found this quote on the Power Electronics trade journal website:
A better and more cost-effective alternative is to mount a second lead wire to each end of the end terminations. This increases the current carrying capabilities of the capacitor and also helps to reduce its ESR and self-inductance. A four-leaded capacitor is more resistant to failure from vibration due to the second lead wire on each end adding strength to the solder connections as well as restricting capacitor movement.
Personally I think it'd be pretty darn unlikely that two seperate capacitors in a can would somehow fuse together in such a way that there was perfect continuity between the two. In addition, I have seen double capacitors, and they usually have the leads on the same side, with a common ground. I'm going with the single-capacitor-with-extra-leads theory. What do you all think?
Kevin Weddle
Feb 23, 2004
1,620
I think a short is possible, but not on both sides as you have said. Maybe both sides have a connection to ground. Could you ground a can. Inspect the traces for ground connections.
Enginuitor
Jul 25, 2004
36
Tore off some of the heat shrink and tested between the leads and the can. None of the leads have continuity to the can. I stand with my position that this is a single cap.
Enginuitor
Jul 25, 2004
36
I don't think this cap is the problem. Interestingly, I removed the SG3524 chip (which controls the voltage and current regulation) and the unit operated exactly the same as it had before! Time to replace the chip, methinks?
Kevin Weddle
Feb 23, 2004
1,620
That is one strange device I must say. It would be interesting to see the circuit. One capacitor with four leads that go to wherever. It could be a parallel path. Have you thought of that? It's like the diode with three leads. They make them that way to realize a certain function. It is actually two diodes that are arranged as pullups to a 5volt line. I think they are inverted diodes. You see them on DIO lines.
ante1
Jan 24, 2004
4,136
Greg,
The SG3524 chip is rated 8 to 40 Volts and you have 65VDC on the inputs. How is the voltage reduced and is the internal 5V ref used by the circuit? A schematic would be very helpful.
Ante ::)
Enginuitor
Jul 25, 2004
36
I traced the VIN lead and it brought me straight back to the zener/reisitor circuit I mentioned earlier. As it turns out, this is actually a crude voltage regulator. The resistor is connected between the positive supply voltage and the cathode of the diode. The anode is grounded. This is a 12V zener diode, so the potential between the anode and cathode is, of course, 12 volts. This is what is used to power the '3524, as well as the voltage source to drive one of the two large can-type output transistors. No wonder the resistor gets hot... it has to drop over 50 volts non-stop!
ante1
Jan 24, 2004
4,136
Greg,
It seems like a strange way to reduce the voltage that much. There can
