PSU repair, found strange cap, need guidance
Enginuitor
Jul 25, 2004
36
Long story short, I set up the back terminal strip according to the strapping diagram for local sensing and control.
It miraculously worked!...
For a short period of time.
Everything was working fine, so to test the current output I put a small wire across the output. I started easing the current up, and it did fine up to about 3 amps, then suddenly the needles dropped to zero. I think I may have heard a small click, but I'm not sure. This is a 10-amp power supply -- What happened??
Now it's in a truly wierd state. When I turn it on, the voltage slowly rises, charging the output capacitor, until it hits the OVP cutoff point (set by a small potentiometer; I have it at about 46 volts) at which point the relay shuts down the output stage. This happens regardless of the voltage settings, though a higher setting seems to make it happen more quickly. Obviously the system is no longer regulating properly.
Currently I am running the manufacturer's calibration procedure to see if that might catch the problem.
By the way, there is a full schematic in the pdf I linked to.
Any suggestions?
Enginuitor
Jul 25, 2004
36
Here is the schematic for those who don't want to deal with the PDF:
Click here to enlarge
ante1
Jan 24, 2004
4,136
Greg,
It looks like U9 / U1 is a switching pre-regulator, the setup maintains the voltagedrop over Q9 to minimize the heat. Do this part work allright? C5 has an unusual symbol but I think you can replace it with a standard but low ESR cap, if it
Enginuitor
Jul 25, 2004
36
Thanks for all your help. Since we're past the capacitor issue, let's move this discussion into my other thread (Electronics Chit-Chat -> "Help with power supply repair") so we don't have to jump back and forth.
