Wanted: Push On Hook Clip Adapter
Status
Not open for further replies.
dave9
Mar 5, 2017
1,191
I'd imagine you can get the clips you solder wires to, for about $1 or $2 delivered from China, and the same for some banana plugs (providing you don't expect high quality for dirt cheap), then add whatever wire type and length you need.
You might also find assembled combinations of the above for cheap from China. $2.18 delivered:
https://www.ebay.com/itm/1Pair-Bana...le-For-Multimeter-Test-Equipment/121705584780
If they're not up to your standards, consider them a backup set and... it's only $2.
eBay is a jungle though, keep looking and there's more to be found, like a little cheaper or a generic version of what you wanted.
https://www.ebay.com/itm/1-Pair-4mm...-Probe-Lead-Cable-For-Multimeter/312193080704
https://www.ebay.com/itm/UT-C01-4mm...xtension-Hook-Probe-Testing-Clip/223085507422
HarryA
Jan 22, 2017
90
Thanks gentlemen but the type I am looking for have a hole in their back end that you slip onto the pointy
end of the existing test lead. Only have one for one meter and on the second meter they are
the screw on type which takes sooooooooooo long to screw on and off. I don't want to have to
exchange the test leads that's a pain also.
dave9
Mar 5, 2017
1,191
My 3rd link was that type, and there are others on ebay too, cheaper than $24 a pair. Some are both push-on, and threaded to screw on at the end of the push-on range.
HarryA
Jan 22, 2017
90
Thanks, I ordered two pair of the Radio Shack clips. No more screwing around ;)
Status
