PUT (programmable unijunction transistor)
b.a. marcus
I've been experimenting with a relaxation oscillator using an NTE6402
(basic PUT). I've been searching the net looking for information to
predict the oscillation time but the datasheets I have found are meant
for professionals. I (a hobbiest) need some information detailing the
math involved in calculating values for C, R, R1, R2 for a given
frequency. I can get oscillation for the time period I desire (4-10
Hz.) on a protoboard, but I need to be able to document calculations.
Can someone direct me to a URL for a tutorial. Or even suggest a hard
copy publication.
W
Watson A.Name - Watt Sun, Dark Remover
copy publication.
I suggest you use a 555, which is well documented and designed to
overcome the limitations of UJTs etc. Did you ever wonder why you
don't see these UJTs and PUTs used anymore? Well..
@@F@r@o@m@@O@r@a@n@g@e@@C@o@u@n@t@y@,@@C@a@l@,@@w@h@e@r@e@@
###Got a Question about ELECTRONICS? Check HERE First:###
http://users.pandora.be/educypedia/electronics/databank.htm
My email address is whitelisted. *All* email sent to it
goes directly to the trash unless you add NOSPAM in the
Subject: line with other stuff. alondra101 <at> hotmail.com
Don't be ripped off by the big book dealers. Go to the URL
that will give you a choice and save you money(up to half).
http://www.everybookstore.com You'll be glad you did!
Just when you thought you had all this figured out, the gov't
changed it: http://physics.nist.gov/cuu/Units/binary.html
@@t@h@e@@a@f@f@l@u@e@n@t@@m@e@e@t@@t@h@e@@E@f@f@l@u@e@n@t@@
Chaos Master
b.a. marcus[[email protected]] said this in sci.electronics.components, at 27 Dec
copy publication.
Use a 555 timer, that is far more "advanced" and "modern" than PUT's. There's a
LOT of info on the 555 timer on the Internet. Just type "555 timer" on Google.
The timer will be far more useful than a PUT in new projects.
Mark Zenier
copy publication.
Wow, talk about non-answers.
The first problem is that NTE is just a parts reseller for the hobby
and service market so they probably won't have anything more than
a skeleton datasheet. So the task is to reverse lookup that part.
That wasn't too hard, as there aren't very many types of PUT.
So I found some Motorola PUT numbers, 2N6027 and 2N6028.
Both cross to NTE6402.
Ok, so whatever part of Motorola who makes PUTs, (if they still
make them), probably has the application notes, online, that they
included in their 1988 Thyristor Databook.
Try On Semiconductor, first, they are the spinoff that make?/sell most
of the non-RF discrete parts that used to labeled Motorola. Most likely
as a big PDF file. Get it, you'll also learn a whole lot about SCRs
and Triacs, too.
Mark Zenier [email protected] Washington State resident
b.a. marcus
copy publication.
Well that doesn't answer my question. But thanks for trying.
I have used the 555 in this circuit and it makes the design bigger and
consumes more power. UJT or PUT is the way to go in this anolog
design. I have extended battery life by at least %100 by using the
PUT. I can slim the PCB by 1/2" or more. Also, with a PUT you don't
have to use an electrolytic capacitor. I am using a .05mf ceramic in
this "non-precision" application. A x555 is overkill in this circuit.
Thats my opinion.
petrus bitbyter
copy publication.
Marcus,
Where did you find the datasheet?
petrus
b.a. marcus
petrus bitbyter said:
Marcus,
petrus
I found several data sheets on PUT and a few good example of how to
use it.
http://www.onsemi.com/pub/Collateral/2N6027-D.PDF
http://www.du.edu/~etuttle/electron/elect10.htm
I guess my math skills aren't what they used to be. The information is
there but I can't hash it out.
Anyway, I'm considering going to TTL for this device. It'll be my
first TTL project. But I will publish the current schematics soon.
b.a. marcus
Yeah, don't you love all of the free advice you get sometimes.
On is where I found the Data/application sheet. It is pretty good actually.
I just need to sit down with pen and paper and work it out.
Thanks for the suggestions.
B.A. Marcus
