PWM application question
KX36
Aug 26, 2011
14
I know you can use PWM to adjust average power level in a device such as a motor or light bulb, but can you use it to power something from a supply beyond its specifications?
E.g. I have a 6Vdc light bulb and a 30Vdc power supply. Can I use a 20% duty cycle PWM to power the bulb, or will the bursts of 30Vdc damage it?
(Let's just say for the sake of argument I can't use a different power supply, but the high currents involved make resistive voltage dropping underirable, wasting lots of power in heat and needing a very large, expensive, heatsunk resistor)
rootboy
Aug 26, 2011
22
I think that you would be just fine. And keep in mind that you could always put a reactor in series (it's what we do for VFDs, and it really helps)
Just make sure it's not a nuclear reactor...
Do you mean an inductor? If so you may need to provide additional protection for the PWM drive so that it doesn't suffer from the effect of switching a highly inductive load.
KX36
Aug 26, 2011
14
Thanks for the replies. How would I work out the right inductance for the inductor? (if that's what u mean by reactor)? With these currents, the dc resistance will have to be low, so that means the part would get big and expensive quickly with increasing inductance, so I would aim for the minimum inductance that does the job.
And would the protection just be the usual parallel diode to avoid flyback voltages?
Cheers,
Matt
rootboy
Aug 26, 2011
22
Well, in this application they are known as reactors, but yeah, it's an inductor. But when you go shopping for one, search for "reactor".
As for sizing the inductor, that's a good question. Usually we let the companies that sell them size them for us. But some sites have an online calculator that you can use.
Here's a short writeup on load reactors:
http://www.mtecorp.com/load.html
I don't know if the math scales, but this pdf might help with the calculations:
http://www.pge.com/includes/docs/pd...e/energystatus/powerquality/line_reactors.pdf
Enjoy! :)
