what pwm controller ic is this ?...
fretkroket
Sep 6, 2024
3
im trying to build a circuit board using a pwm input signal.
i found this simpel PWM controller relais and it has a no-name pwm ic controller to it.
i would like to know if maybe someone knows this .. has a datasheet or software that is necessary to use it.
this is a 5v pwm relais from aliexp...
greetings
14,317
Labeling simply unredable. This could be any chip...
pwm or controller or relay? Not both at the same time. You can't (at least not in a meaningful way) use a relay for pwm control.
bertus
3,877
It can well be that the chip has been " mistified" to avoid copying.
Bertus
fretkroket
Sep 6, 2024
3
its pwm relais for rc car or rc toy.
i have checked a bunch and they all have the same dimple in the corner. yet no number at all.
i have desoldered one just to see if it has a number on the bottom , yet no luck.
i thought mayb there is someone on this forum that knows what ic they use.
danadak
Feb 19, 2021
1,104
Possible ATTINY85 type.
Here is what it takes to program it to make a V to PWM control :
You config blocks and mBlock converts that to Arduino code (right window), you cut and paste into
Arduino and program board/chip.
Regards, Dana.
danadak
Feb 19, 2021
1,104
2 of the cables, Red and Black, marked + and -, seem to indicate thats power
supplied to board.....
