Question about circuit boards. Repairing a tv
Brick8105
Apr 25, 2017
I'm replacing a board in a Samsung plasma TV. When I look up the part number as well as the board numbers I find the board I'm looking for but with one difference, I find that some of the boards have what look like a "resistor connected to a small heatsink and the same board model numbers identical have the heatsink resistor spot etched onto the board but without the components. I figured that if I buy the replacement board that comes with the heatsink combo then that may give me a little better security? Because my board that isn't working anymore did not come with those components originally. Like I said both board have identical model and product numbers ect. Will either board work?
Tha fios agaibh
Aug 11, 2014
2,253
I would say yes, but you should verify this with the vendor.
It's not unusual to have revisions on a board to resolve problems found after first run.
If the added heatsink is the only difference, I'd say your fine provided there's no clearance problem.
Brick8105
Apr 25, 2017
Ok thank you very much
