question about ohm's law
Chengjun Li
Oct 21, 2014
84
About Ohm's law, wikipedia has the following statement
“Materials and components that obey Ohm's law are described as "ohmic" which means they produce the same value for resistance (R = V/I) regardless of the value of V or I which is applied and whether the applied voltage or current is DC (direct current) of either positive or negative polarity or AC”
We also know that resistance of a resistor is a function of temperature. For example, Jameco 100 Ohm resistor has a temperature coefficient of 350ppm.
My question is at higher voltage, the heat generated is larger due to P=V2/R, so the partial temperature is higher, then the resistance should change to smaller value, which is conflict with above statement of Ohm's law. Could anyone give me some clue of this problem?
Thanks.
ramussons
Jun 10, 2014
475
About ohm's law, wikipedia has the following statement
We also know that resistance of a resistor is a function of temperature. For example, Jameco 100ohm resistor has a temperature coefficient of 350ppm.
My question is at higher voltage, the heat generated is larger due to P=V2/R, so the partial temperature is higher, then the resistance should change to smaller value, which is conflict with above statement of ohm's law. Could anyone give me some clue of this problem?
Thanks.
The blue statement is valid on a condition that all other parameters are constant - temperature, pressure, frequency, ... The only variables are the Voltage / Current.
alex Chiu
Apr 1, 2015
14
Ohm Law still value.
P=VI, =
If R = Constant, Higher V, higher I, however, when consider heat, R reduce, I reduce,
14,487
Great response Ramussons .... spot on :)
Colin Mitchell
Aug 31, 2014
1,416
should be
then the resistance should change to higher value
Ratch
Mar 10, 2013
1,102
Thanks.
You should read this link http://www.electro-tech-online.com/threads/ohms-law.430/page-2 starting with my contribution on post #22. Then we can discuss it further.
Ratch
