Question on the Plants Watering Watcher circuit
kiewty
Jul 9, 2004
5
hihi, sorry for asking u a favourite, :), can you send it to me, to my mailbox, [email protected], 'coz i'm scare that the admistrator of the page late to post ur new projects, this wednesday i need to pass up the projects with reports, so, i need it asap. But anyway, if u felt tat is not very conveniece for you to do that, just forget about it. ;D
Hope u will send it to me.....
kiew
kiewty
Jul 9, 2004
5
oo, thz, i got it, it posted in the new projects...nice work.... ;D
Olihou
Oct 1, 2004
48
Dear Audioguru
I have read through the conversations in one breath. The subject is of much interest to me as a electronics amateur and plant lover. You have really done a good job!
I will certainly try out your circuit shortly.
Thank you very much!
audioguru2
Apr 6, 2004
12,022
Hi Olihou,
Welcome to our forum and thanks for the compliment.
My circuits have been blinking (I let my plants dry-out before watering again) for over 3 months with the original AAA battery cells and the 3.0V has dropped to about 2.7V. I'll replace the cells when they reach 2.0V.
The LEDs are probably down to near half-current now, so the next 0.3V of battery voltage drop will take 6 months. When dry, the LEDs seem to blink just as bright as with new batteries since the eye's response to brightness is logarithmic and therefore half the current through an LED looks almost the same.
The plants with the circuit grow better than those without, so it helps them. Maybe the 2KHz through the soil stimulates their roots. My ordinary tinned copper-wire probes have not corroded.
If you use the really bright wide-angle LEDs that I recommend, you will like it very much.
Olihou
Oct 1, 2004
48
Dear Audioguru
I have succeeded in building the unit according to your design. It is working exactly as you have described. I am completely satisfied with the circuit, except that the brightness of LED does not seem to give a clear indication of the level of dryness. The LED I have used is of ultrabright type, the brightness of which changes very little when the soil resistance (simulated by a trim-pot) varies from 1 kohm to 100 kohm and to infinity. :-[
I have hence realized the beauty of the design you have proposed im May:
"My new idea is to have a flashing LED indicate soil dryness. When the soil is wet then the LED is off. As the soil dries, the LED begins flashing slowly. As the soil dries even more then the flashing-rate increases. When the soil is very dry then the flashing-rate will be so fast that the LED will appear to be on steadily."
Are you developing a circuit like this, or will you? :D
Thanks and best regards,
Oli
audioguru2
Apr 6, 2004
12,022
Hi Oli,
I am glad that your project works well.
Is your soil different from mine? I have designed the circuit so that very wet soil that is only 47 ohms (with about 50mm of the probes in the soil and spaced 0.7" apart) turns off the LED. Very dry soil that is 100K or more makes the LED flash very brightly.
One of my plants was fairly dry yesterday and its circuit was flashing fairly brightly. About 1/2 hour after watering it with a weak fertilizer solution (ordinary water works the same), the LED turned off. The soil was damp, not soaked. This morning the circuit is flashing dimly and the soil is just right, not damp nor dry.
I tried resistors just now:
47 ohms = LED is OFF
100 ohms = extremely dim flashing, seen only in a very dark room
1K ohms = very dim flashing that is clearly visible in a brightly lit room
10K ohms = flashing that is not dim nor bright
100K ohms = almost full brightness, very bright flashing.
Different LEDs vary in the way that they shine:
1) Some are linear only at very low current, up to about 2mA, then "saturate" so that 4mA gives only 1.8 times more light than 2mA, 8mA gives only 3.0 times more light and 16mA gives only 4 times as much light instead of 8 times like the current. Yours are probably like that.
2) My LEDs have a linear brightness increase with increasing current so 4mA produces exactly 2 times as much light as 2mA, 8mA is 4 times and 16mA is 8 times. The max (new battery) peak LED current in my circuit is about 39mA and the LED's voltage is 2.15V. With a fairly dead (2.0V) battery, the max peak LED current is 8mA and the LED's voltage is 1.8V. Of course the 2KHz PWM pulses at the 2Hz flash rate have a very short duration so that LEDs with a max continuous current rating of only 30mA are not stressed.
3) Other LEDs get more efficient with increasing current. 20mA produces 3 times as much light as 10mA, etc.
Can't you purchase or get samples of the LEDs that I recommended?
I was dreaming when I thought of changing the flash-rate with changing resistance. It would be fairly easy to make it flash very slowly when the resistance is high (dry soil) and flash quickly when the resistance is low (wet soil), but that operation is backwards and it would be too complicated to reverse it.
Olihou
Oct 1, 2004
48
Dear Audioguru
Thanks for your prompt reply. I will check the performance of my LED. It is one with unknown part number, just picked up from the shelf.
I agree that as you said "It would be fairly easy to make it flash very slowly when the resistance is high (dry soil) and flash quickly when the resistance is low (wet soil), but that operation is backwards and it would be too complicated to reverse it.", or in academic terms, it is easy to build a "resistance-to-delay" circuit but not a "conductance-to- delay" circuit".
Having said that I am still dreaming for a not too completed circuit for the latter -- am I too much a perfectionist?
Nevertheless I would think that the present circuit is already good enough for the practical use. After all one's main concern is when to water the plant, and a rough idea of the soil dryness is just sufficient.
Thank you. May I come back to you after further experimenting.
Oli
audioguru2
Apr 6, 2004
12,022
Hi Oli,
In addition to using LEDs that have linear brighness vs current, make sure that they are wide-angle so that they can be seen when not pointing directly at you. Many "ultrabright" LEDs have a very narrow beam.
Another problem with having a reverse resistance-to-flash-rate circuit would be its high average current consumption when the soil is dry. Do you want a circuit with big and heavy D cells? (A potted plant toppler.) Or requiring replacement of fairly expensive AAA or larger AA cells every few days?
My existing circuit draws very little current, even when flashing brightly, so that is the way it will stay.
Olihou
Oct 1, 2004
48
Dear Audioguru
Thanks for your comments on the LED. Mine is really one with a beam of very narrow angle and I will look for a replacement.
I think that current consumption might not be a problem for the resistance-to-flash-rate option, as we could control by design a low flash rate to reduce the average current. For example, from 1 pulse per 5 second for very wet to 2 pulse per second for very dry (this is a range of 10 to 1).
Do you agree?
Thanks.
Oli
audioguru2
Apr 6, 2004
12,022
Hi Oli,
I'm not talking about us electronic genius's, but the average (stupid?) person probably won't be able to comprehend a flash rate change of only 10 to 1. Besides, a flash rate of 5 seconds is so slow that you could walk right by and not see it between flashes.
I designed a communications system for the government. (Lots of stupids there!) I had one type of warning signal make a low frequency beep slowly, and another warning signal make a high frequency beep quickly. They complained that there was no difference! ;D
Olihou
Oct 1, 2004
48
Dear Audioguru
I have obtained the following measurement results:
Ohm between probes On Pulse of LED Battery Current
47 Nil on scope 0.6 mA
100 0.3 uS 0.6 mA
1 K 1.5 uS 0.7 mA
10 K 14 uS 0.8 mA
100 K 100 uS 1.0 mA
Opne circuit 600 uS 2.0 mA
Note: WIth R1=560K and C1=.002 uF, the operation frequency is around 800 Hz, i.e. T=1.25 mS
R3=12 Mohm, R4=100K, giving a pulse of 30 mS at 1 pulse/2 seconds
My observation is that for
47 ohm and below, no visible light from LED
100, a little bit light
1 kohm, easily visible
10 kohm, brighter
100 kohm, even brighter
open circuit, very bright
My feeling is that if, in actual use in soil, the soil resistance falls in similar range as above, then we can tell from the brightness the degree of dryness quite confidently. However, if the range is only from 100 kohm and above, i.e. the LED is seen quite brigt to very bright all the time, then it would be a bit difficult to tell the degree of dryness. Of course this will very much depend on the separation distance of the probes, the sizes and shapes of the probes, the chemical composition of the soil ......
This should be my next steps of experimenting with this wonderful toy !
Comments are welcome !
Oli
audioguru2
Apr 6, 2004
12,022
I added a resistor across the probes to reduce the modified project's soil-resistance range, and to fix the problem that happened without it, when sometimes the LED stayed off if the probes were suddenly given a soil resistance that equalled R2 (cancelling the signal at P2).
Hi Oli,
Your measured pulse widths and battery current are a little more than twice what I measured, which is due to your change of the oscillator's frequency from my 2KHz to your 800Hz.
Your pulse width keeps increasing with an inter-probes resistance more than 100K, which makes me believe that you did not install R8 (47K between the probes). My quote above shows a problem this will cause, but your timing has to be just right for it to happen (a resistance of 100K between the probes exactly at the moment that Probe 1 goes low). Without R8, my circuit had that problem occur once or twice if I randomly inserted the probes into 100K soil ten times.
Another problem happened without R8. As the soil's resistance gradually rose to 100K, the LED's brightness kept increasing. At around 100K, the brightness suddenly dropped, then didn't rise any more as the soil's resistance increased to open circuit.
Adding R8 fixes both problems and reduces the battery current (and therefore LED brightness) with a very high resistance between the probes.
Olihou
Oct 1, 2004
48
Dear Audioguru
Thanks for your comments.
I hope you do not mind that I have not follow your design faithfully. I have just used parts readily available. Hence the electrical performance is different from what you have built. :( However functionally I trust it is as good as yours. :)
As a matter of fact, I do have R8 in the circuit. I have used 56 kohm instead of 47 kohm.
I do not have time yet to do what I intend to do: to study and hence to design the probes so that the equivalent soil resistance would fit the range of the circuit best, and so that the change of brightness of LED would reflect closely the condition of soil.
I will report to you and all interested in due course.
There is one more thing I intend to do: following this "watering watcher" project, I would like to build an automatic "watering" device. In fact this is what I have dreamed of before the very fortunate encounter with you guys at this wonderful fourm ! :D
Best regards
Oli
audioguru2
Apr 6, 2004
12,022
Hi Oli,
I have been thinking that my circuit probably won't work if the plants are watered with distilled water, and the use of organic instead of chemical fertiliser. I will try it with synthetic soil too.
I was amazed at the low resistance of my plain and activated-charcoal-filtered (no difference) tap water.
You have a good idea to make an automatic watering system. The outdoor ones that I have seen operate only when it is raining! ;D
Olihou
Oct 1, 2004
48
Hi Audioguru
In my place I am given to know that commercial "distilled water" is not trully fully distilled -- there are still minerals such NaCl as ions which makes water conductive. Even if it is 100% distilled and free of minerals, there are still likely minerals in the soil.
So there is little chance that out circuits would not work -- unless you do use 100% distilled water AND the synthetic soil you have mentioned (What actually is it? I do not know if there is anything like this in my place?) ;D
Oli
audioguru2
Apr 6, 2004
12,022
Hi Oli,
The "non-soil" is called Pearlite or Vermiculite. I doubt if it is conductive. I have seen potted plants growing in that light-weight white stuff.
Don't you think that my circuit will fail if they were watered with "pure" water?
Olihou
Oct 1, 2004
48
Hi Audioguru
Of course not as, any pure water getting into contact with the dirty soil will become not pure. Minerals in the soil will certainly be dissolved in water.
I wonder if there is any "soil" without minerals. If there is, then it is not suitable for plants -- plants need nutritions like N, P and K. They are normally in the form of soluable minerals in soils.
I would very much like to hear any encounter of situation that the circuit fails. ::)
Thanks.
Oli
dicky
Oct 20, 2004
4
If you place a 5K or 2K [depending on the current in the circuit]t-pot in the LED circuit you can alter the threshold of operation of the LED and dimming will occur. I haven't seen the circuit so I may be talking thru my hat......Dicky
Olihou
Oct 1, 2004
48
Hello dicky
Dimming by a trim-pot? What do you mean? What do you want to do?
Oli?
