Cliff
- Jan 1, 1970
- 0
Characteristic impedance and DC resistance are the same if the line is
infinitely long and unterminated.
How do you arrive at that one?
+V>---O
S1 | <--O--[AMMETER]--+--[INFINITELY LONG COAX CENTER CONDUCTOR]-
[VOLTMETER]
GND>---------------------+--[INFINITELY LONG COAX SHIELD------------
1. Close S1
2. Read the ammeter and record what you read as 'I'
3. Read the voltmeter and record what you read as 'E'
4. Calculate the resistance of the cable:
R = ---
I
5. Since a DC source is driving the cable and the voltage and
current remain constant, there must be no reactive terms which
need to be considered, so:
Z = sqrt R² = R
Thinking about it a little differently, if you consider that when
you close the switch the inductance of the center conductor is
limiting the current that can charge the incremental capacitance of
the cable as the edge propagates down the cable, then that limit and
that capacitance define how much current the voltage source driving
the cable needs to supply while the edge is moving down the cable,
and, since
R = ---
I
we wind up back where we started.
http://www.allaboutcircuits.com/vol_2/chpt_13/3.htmlDavid wrote:
Bullshit.
David wrote:
Bullshit.
So the longer conductors are not shorter after all? How long
do you suppose that they are compared to the central conductor ???
Now, about the speed of light in those conductors ... a lead or
a lag between the signal's phases?
David said:
If you mean by "DC resistance", the impedance you would see at the input
of an infinitely long line, it's not bullshit, it's perfectly true, even
if the line is made of zero-resistance conductors. You'll just see the
line's characteristic impedance.
Quite true if you define DC resistance as the applied voltagr divided byDavid said:
So why are you all freaked out?For god 'amighty sake, read your own reference and then read what I
wrote again. Now, read your reference *completely* again.
*Characteristic Impedance*. In your reference, they give exactly the
same formula as I did.
Jeeze.
the, (constant for an infimite line), charging current.
As a practical matter, to match a generator to a given line, you can use
a long length of co-ax cable to simulate a load at the cable's
characteristic impedance. The line needs to be long enough to have
~10-20 db loss at the frequency in use.
Fred Abse wrote:
*Please* , read my post on calculation of characteristic impedance. I
am not talking about Infinite length transmission lines. I am talking
about the calculation of impedance.
Fer krissake, keep the discussion in context.
What do I give a shit about infinitely long lines. I don't use 'em.
Valid only if you want to discuss voltage and current distribution.
That's not where this started.
Jasen said:["Followup-To:" header set to sci.electronics.basics.]
Twisting wires helps reduce noise induced from ambient H fields. If you
have a high ambient E field, you can still get common mode noise coupled
to a bare twisted pair. Particularly on a high impedance circuit. This
becomes a problem at low signal levels, where a CMRR sufficient to
reject the noise may be impractical. Low signal level circuits are where
one finds high impedances as well. In this case, carefully designed
shielding can help.
transformers typically have very a high CMRR. this may be whay they are used
in network cards.
What matters is the speed of light in the dielectric *between* the
conductors. That's where the traveling electromagnetic wave is.
Characteristic impedance is purely a function of the
capacitance and inductance distributed along the line's length, and
would exist even if the dielectric were perfect (infinite parallel
resistance) and the wires superconducting (zero series resistance).
Velocity factor is a fractional value relating a transmission line's
propagation speed to the speed of light in a vacuum. Values range
between 0.66 and 0.80 for typical two-wire lines and coaxial cables.
For any cable type, it is equal to the reciprocal (1/x) of the square
root of the relative permittivity of the cable's insulation.''
+V>---O
[VOLTMETER]
1. Close S1
R = ---
I
Z = sqrt R² = R
and, since
R = ---
I
Correct. There must be a return path to the generator or battery.So if all we have is a bare wire no current can flow?
The transmission line is infinite.I think most of you people are somewhat confused when dealing with the
characteristics of transmission lines of all types. For example, the
mixing of impedances as indicated above results in a "return loss" or
reflection loss. There also ohmic losses in transmission lines as well
as dielectric losses. Impedance is a constant characteristic of a
coaxial transmission, not a variable. It is a fixed quantity and is
calculated in the following manner.
+V>---O
[VOLTMETER]
1. Close S1
R = ---
I
Z = sqrt R² = R
and, since
R = ---
I
In the DC case the current would drop off with time
as the capacitance near the source becomes charged
and resistive effects predominate.
