Re: Strange problem with low energy light bulb
GregS
Eeyore said:
GregS wrote:
Eeyore wrote:
Arfa Daily wrote:
With a bit of work, I'm sure that they [LEDs] will
also get to the point where they can replace a standard filament bulb, in
the same sized package, unlike a CFL which has to accommodate the ballast.
To run LEDs efficiently from 240V AC will also require some active electronics.
I see no-one ever factors in the power losses that'll be associated with that.
When you use up the watts, you get heat. The lamp has to efficiently get
rid of it. May even need a fan.
Quite possibly so. How many watts does the fan need ?
I have one here that's 40mm sq. It still uses 1W.
I'm actually using a CPU sink/fan combo, but the LED's are epoxied to a copper
plate. I even have diamond dust as a buffer/insulator. To close space the LED's
I needed the best thermal transfer. Did I forget to mention the Peltier device.
I am also using unmounted LED's.
Nothing is compact. I use a large variable supply.
And the efficiency of that is ?
There is 45 watts going to the LED's.
About 20 [email protected] amps. 3 series sets of LED's. You cannot look at the light.
The device was intended to be flashed in the final form. peaking at about 60
watts.
So how do you control the LED current ? I imagine you may have current sharing
issues with parallel chains
too.
What's the AC input watts ?
Not sure, but I am not concerned with efficiency. I am concerned with heat dissapation.
With same batches I have. the individual specs are very close together, so
load distribution is no problem at all. I use a variable voltage/current supply. I
just have to watch to easily move the controls. This is just a test hookup
for now. I am using blue and green colors, they will be strobed to get effects.
A few months ago I bought a batch of cool white 3 watters. I intended to put
some around the house and control them with X10. It
got too complicated with the X10, and I didn't really like the cool white.
The blue LED's are really neat. I have never seen that mystical color temperature
out of LED's before.
Don Klipstein
message news:[email protected]
My searching finds ordinary 40 watt bulbs rated at from 280 to 355 lumens.
More lumens at a given wattage rating generally means a shorter life. IME
incadescent lights draw significantly less than their rated power, so their
light output may also be less than spec.
280 to 355 lumens is about half the light output of a 11 watt CFL. BTW, my
experience with CFLs pretty well matches the lumen output levels that you've
mentioned, Graham.
In USA, plenty of 40 watt incandescents are rated to produce 445 to 500
lumens. My experience is mostly CFLs consuming 25-30% of the electricity
of "standard" incandescents of same light output.
About twice the brightness from about one quarter the power works for me!
We've seen vastly improved bulb life, which is especially helpful when bulbs
are located where they are hard to replace, such as at the top of a 3-story
stairwell.
My first project was in a large basement room that was frying about one
halogen bulb (of 32) per week, partially due to overheated fixtures. We
pretty much relamped the room almost twice a year. We put in 2 CFL bulbs
per fixture and still dropped the fixture's internal temperature to under
110 degrees F from more like 140. Lumen output per fixture almost tripled.
We were also able to get a more pleasing color temperature. This room is has
been relamped for about 3 years. We are currently replacing about one bulb
per year.
Everyone else who wants to relamp with CFL, watch out with recessed
ceiling fixtures. Strangely nough, CFLs are actually more efficient at
producing heat conducted to the immediately surrounding air than
incandescents are, by producing a lot less infrared. I tried this - a 42
watt CFL heats up a fixture slightly more than a 60 watt incandeswcent
does, at least when I tried it. Make sure your fixture does not get too
hot for the CFL. Not only can excessive heat shorten their lives, but
also excessive heat can make them run dim as well as excessive cold can.
I've done a fair number of fairly large (i.e., 8 or more bulbs per room)
incadescent (mostly halogen) to CFL upgrades, with extremely positive
results. In every case the fixtures were previously loaded up with
incadescent bulbs rated at the fixture's maximum power. They were providing
poor to marginal lighting.
When I can maintain the power usage at a constant level, the results of the
CFL upgrades are brilliant. When I'm forced to run the fixture at reduced
power levels because of bulb space limitations, the results are still
striking and very helpful.
The building in question had lighting engineered to 1950's standards. The
lighting had become ineffective because of rising expectations. Actually
upgrading the fixtures would have been prohibitively expensive.
Don Klipstein
Issues with LEDs today:
Color rendering
Diffusion
Once those are solved effectively, they will be excellent
alternatives. My guess is 5 years to color rendering, and 5 more to
diffusion. Most LEDs today filter a single color to a specific
monochromatic output.
No, they dopn't filter them - the chips make a specific band of
wavelengths.
Even the LED-type flashlights are very heavily skewed to the blue end of
the spectrum in order to get sufficient brightness,
I just saw some at Target today that appeared to me to have color
temperature around 5500 Kelvin.
and require multiple LEDs to get even a minor beam with
very poor diffusion.
I am talking about ones that have a distinct beam and about as much
light output as a 3-D-cell Mag Light.
Peter Wieck
Wyncote, PA
Don Klipstein
The length of service issue with LEDs is very dependant on the way they are
driven, if you are to get the maximum of 100,000 hours plus out of them.
However, that said, even if not driven properly - ie not pulsed - from what
I have read, they are still good for 40k hours, before the light output has
dropped by 50%.
White LEDs do better unpulsed. Used as directed, most are rated for
50,000 hours. The main reason for pulsing LEDs nowadays is to dim them in
a linear manner, such as in variable color fixtures and large video
screens. LEDs often have efficiency and color varying when instantaneous
current is changed, and output and color are often specified only at the
"characterizing current". Different color LEDs have different general
trends in how efficiency varies with current.
As far as colour rendering goes, I agree that this can be
achieved with combinations of RGB LEDs, and I'm sure can be made as good or
better now, as CFLs are ( not that I'm saying theat CFLs are good of course
... !) Just a few days ago, I saw somewhere that one of the manufacturers
has come up with LED chips bonded to a sort of 'ball on a stick' shape, so
many small chips face in virtually every direction around a sphere, to get
over the point-source poor beamwidth issue.
BTW, Philips CFLs = China ? Not any more, it would seem. I picked one up in
the supermarket tonight to have a look. It said " Made in Poland " ...
Don Klipstein
Currently, white LEDs are in fact blue LEDs coated with a fluorescent
substance, so probably the overall light quality will be quite similar
to CFL.
Actually, it's more like that of somewhere between a "cool white" and a
"daylight" old-fashioned fluorescent, with similar color distortions.
There are now some warmer white and higher color rendering index white
LEDs.
Don Klipstein
The brightest LEDs do unfortunately have that cool blue 7000K or so colour temp.
There's a significant trade off in efficiency for the 3000K ones.
They are now getting color temperature as low as mid 4,000's with no
compromise in light output.
Don Klipstein
In my experimental 45 watt, 9- 5 watt Luxeon array, I use copper, aluminum, and a fan.
DC drive is nice.
The normal home doesn't have DC. What do you use for current limiting
and how much power does that dissipate ?
Electronic ballasts for fluorescent lamps (including the ones in all
spiral and most other screw base CFLs) require DC, so require conversion
of AC to DC, and for that matter back to AC of a higher frequency. Many
of those don't have huge losses, in fact usually less loss than iron core
inductive ballasts.
Don Klipstein
http://www.lumileds.com/products/line.cfm?lineId=19
145 Typical lumens from 700mA @ 3.6V, or 58 lumens per watt. The LED is
a surface mount chip 3.1 x 4.6 x 2.1 millimeters in size. A thin strip
of 12 of these chips puts out light comparable to a 100W tungsten lamp
but only uses 30W.
145 typical lumens at junction temperature 25 degrees C for the highest
brightness rank in the datasheet. Now, what about with a heatsink
temperature of 35 degrees C and for the highest brightness rank in the
Future Electronics website?
30 watts into these means probably about 25 watts of heat. Hmmm, what
if you mount a dozen of those onto a heatsink the size of the tip and
heating element combined of a 25 watt soldering iron? What would the
heatsink temperature reach then? What does the datasheet say performance
is at that temperature?
With a good size heatsink to stay at a comfortable temperature with 25
watts, I don't see it looking like a universal incandescent or CFL
replacement just yet.
I'm using 8 of the older Luxeon K2 LEDs in a bicycle light. The output
is nothing short of impressive. It's brilliant at just 5W of input
power. Crank it up to 40W and it puts car headlights to shame.
That I believe!
Don Klipstein
The colour temperature won't be anywhere near comparable.
In any case don't 'white leds' use the same phosphor method of producing light
that CFLs do ?
No, they use a different phosphor made for LEDs. Color rendering of
white LEDs is more like that of "old tech" halophoaphate fluorescents than
like that of CFLs. At least the color rendering index is somewhat better
than that of "old tech cool white".
Don Klipstein
Higher intensity. Might be nonlinear, as in greater efficiency if you pump
them harder. Might be different materials. I don't know for sure though.
White LEDs are nonlinear, generally with efficiency maximized at some
fraction of rated power.
Definitely smaller size, so if you're going to be a stickler for full
context such as analysis of lumens per watt of actual mains input, you must
take all of the context. People have alreay said (rightly) that LED lamps
won't have the trouble that CFL's have in fitting most current luminaries.
That's obviously important regarding watse and expense.
When an LED or an LED cluster has to dissipate 20 watts of heat, it will
probably have to be bigger than a CFL of same power input.
More: LED's are growing more efficient all the time. It might be that in
future these lamps might be directly driven by encapsulated laser diodes
emitting near UV to pump phosphors. Laser diodes have efficiencies beyond
low pressure sodium, they leave it in the dust.
There are some high power IR laser diodes more efficienct than LPS.
Other than those, laser diodes are less efficient than most sodium lamps.
Phosphors have a loss. I expect the ultimate in LED efficiency in the
future will have at least some of the light being the radiation produced
by the LED chips, rather than by phosphors.
Arfa Daily
GregS said:
Eeyore said:
Eeyore wrote:
GregS wrote:
bulb, in
with that.
get
the LED's
and a fan. DC drive is nice.
and how
about 60
watts.
sharing
too.
dissapation.
supply. I
effects.
put
temperature
They are changing over the emergency vehicle beacons here in the UK now to
blue LEDs, and as you say, the colour is such a brilliantly intense blue,
that they are far more visible as being emergency vehicles over a much
greater distance, than ever the blue plastic-filtered zenon flashes were.
Arfa
Lostgallifreyan
[email protected] (Don Klipstein) wrote in
will
Ok, but try thermally coupling a CFL, or any part of one, to a heatsink.
LED's and their drivers are much more easily adapted to use existing
structures to carry the heat away. That's why they can occuppy smaller
volumes. This is actually done, I mentioned the Clifton Suspension Bridge
in another post, that's covered from end to end in them, they're tiny, and
extremely bright, and they use a small metal cowling to carry heat from the
emitters. They're not 20 watts, more like 10, but the total size of the
lamp is similar to a low-volt halogen, far smaller than an 11 watt CFL.
Lostgallifreyan
I think so too. And I hope so. Phosphors don't allow colour mixing, and
that's one of the biggest strengths of LED's.
Lostgallifreyan
Ok. I thought more laser diodes were but never mind.. Aren't most class 3B
visible red diodes around 20% efficient or more though? That still leaves a
lot of headroom. Tungsten is often said to be 1% to 2% efficient at making
visible light. So a 100W incandescent 17 l/W at 1% to 2% places the Cree
XR-E's 50+ l/W at 3 times that, up to 6%. These are loose figures but they
suggest that if LED's reach efficiencies like DVD writer diodes, maybe 3 to
4 times the current efficiency can be had. (Not including phosphor losses,
but including LED driver losses). These figures are assuming Imax, 1A per
emitter, if LED's become cheap enough to double the emitter count and drive
each at 500 mA, the efficiency will go up by 50% or more.
Eeyore
LEDs.
I've yet to see a spectrum published for those 'white' leds. I assume it must be
similar to CFLs.
Graham
Eeyore
4500K is still somewhat blue for most peoples' taste.
Graham
Eeyore
DC drive is nice.
inductive ballasts.
I was asking about LED drivers not CFLs.
CFLs already include those losses in their stated power. LED fans only ever quote the DC
input power required for the 'chip'.
Talk about an uneven playing field !
Graham
Eeyore
visible light.
Wikipedia says 2.6% for the ubiquitous 100W tungsten filament bulb and 3.5% for
quartz halogen.
http://en.wikipedia.org/wiki/Luminous_efficacy
Graham
Jasen Betts
that CFLs do ?
some have yellow fluorescent dye and a blue LED die, it's sort of the
same, but I think the fluorescent lamp has a better spectrum.
Bye.
Jasen
