johndeverill
- Nov 16, 2004
- 40
- Joined
- Nov 16, 2004
- Messages
- 40
Hi all,
There is probably a very straightforward answer to this so you will have to excuse my ignorance.
I have a PC fan controller that I want to run on batteries. It came with the standard 12v,-ve,-ve,5v molex connector.
I connected the 12v wire to a 12v battery pack +ve. I then connected another wire from the +ve to a 5v regulator and onto the 5v wire. I then connected the 2 ground wires and the regulator ground to the battery pack -ve terminal.
The LCD backlight comes on and that's it. I am going to be installing this in my car so should all ground connections go to the body earth of the car?
If anyone can help with this it would be great as I'm sure it's a simple problem that I just don't have the knowledge to fix.
Thanks in advance
John
Thanks in advance
John
