Reassurance on Dual Polarity Power Supply Design
bma1984
Feb 28, 2012
I am hoping someone can shed some light on a concern I have regarding a dual polarity power supply that I am constructing. I am naturally a nervous wreck when it comes to big things such as capacitors potentially blowing up in my face. Having recently made a very amateur mistake and getting pelted in the throat by a 10uf cap wired backwards, it has caused me to be even more cautious and understanding when dealing with caps 100's of times larger. I have pretty much completed the + voltage rail of the supply, and it is working as expected. Before I wire up the the - voltage portion, I just wanted to get some clarification. I am basing this design on what seems to be a tried and true circuit, so I have no doubts it is safe. In the schematic attached, I have circled in "red" the area of concern.
Given a +24v and -24v and 2 10000uf 50v smoothing capacitors. It appears from the schematic that the potential across the 2 caps is 48v RMS. With peak voltages, it is well over 50v (the capacitor rating). Would not both caps charge to that potential? I know the answer is half... but this is where I'm looking for clarification.
Is it because of Kirchoff's Law? ex.
Vab = Vc1 +Vc2
or
48v = 24v + 24v
Also, one other question pertaining to this circuit. I am using a toroidal transformer with 2 output coils on the secondary. I have tied the middle 2 wires together for a center tap. Is it perfectly safe and reasonable to attach this center tap to ground?
Thank you so much for any help!![/B]
Rleo6965
Jan 22, 2012
585
Each capacitor 10,000 ufd with 50V working voltage will be charge of 24V. So, its safe.
Each capacitor charges up to half the value of the unregulated power supply because they are connected to a common ground.
Beware that the common ground is -ve for the +ve side of the supply, and +ve for the -ve side of the supply.
