adrian1472
- Jan 1, 1970
- 0
I followed the instructions on the site about recelling a lithium ion battery pack but unfortunately it didn't work out quite right.
I have a 6 cell battery pack from my gateway which I recelled when I put the battery back in the laptop it ran the laptop but it wouldn't charge when I plugged it in. So I ran it down hoping that it may charge once the voltage dropped, I was wrong. I don't really know where to go from here. Here is some of the info from about the battery that may be helpful.
adrian8@gateway-ubuntu-sda8:~$ cat /proc/acpi/battery/BAT0/info
present: yes
design capacity: 57720 mWh
last full capacity: 11888 mWh
battery technology: rechargeable
design voltage: 11100 mV
design capacity warning: 3996 mWh
design capacity low: 0 mWh
cycle count: 0
capacity granularity 1: 355 mWh
capacity granularity 2: 355 mWh
model number: W35052LB
serial number: 111005200
battery type: 4C 69 00 00 00
OEM info: Gateway
adrian8@gateway-ubuntu-sda8:~$ cat /proc/acpi/battery/BAT0/state
present: yes
capacity state: ok
charging state: charging
present rate: 0 mW
remaining capacity: 1 mWh
present voltage: 10974 mV
adrian8@gateway-ubuntu-sda8:~$ acpi -V
Battery 0: Charging, 0%, charging at zero rate - will never fully charge.
Battery 0: design capacity 5259 mAh, last full capacity 1083 mAh = 20%
Adapter 0: on-line
Thermal 0: ok, 52.0 degrees C
Thermal 0: trip point 0 switches to mode critical at temperature 100.0 degrees C
Cooling 0: LCD 0 of 7
Cooling 1: Processor 0 of 10
Cooling 2: Processor 0 of 10
Thank in advance for any help.
present: yes
cycle count: 0
OEM info: Gateway
present: yes
capacity state: ok
present rate: 0 mW
Adapter 0: on-line
