Recharge circuit
mostafa14
May 29, 2013
3
Thank you..
The box marked [?] is a lithium ion charger.
Of course, a 5V supply will have a hard time charging a 7.4V battery.
An almost acceptable option is a current limited voltage regulated source. In this case 8.4V and the appropriate current (0.5C is usually OK).
And especially note -- current limited, not rated current!
mostafa14
May 29, 2013
3
Thank you steve .
but what is the different between current limited and rated current!
and if you have a circuit diagram please share.
Thank you.
14,487
Thank you steve .
Thank you.
Current limited = a power supply that cannot put out more current than what it is limited to
Rated current = the amount of current a device will need to run correctly
so for example with some rechargable batteries, you may need a current limited power supply so that the rated charging current of the batteries is never exceeded
so you can see 2 very different thing :)
