Well, the tape option would work, but wouldn't that require a LOT more in the way of components, space and overall power?
A COB might not be a bad idea but I couldn't begin to tell you where to go to get that designed, much less produced cheaply... Unless you're planning a full production run, in which case I'd still probably prototype the first couple using ISD chips, then go with COB when you can afford to hire out for it.... as far as I know it's nothing most people (even hobbyists) could design much less make from home.
