Regulator to limit 12v DC current
georgewalker
Feb 18, 2020
14
I'm interested in a suggestion for a rectifier component or circuit to limit the current in a circuit to between 200mA and 450mA.
Audioguru
Sep 24, 2016
3,656
Why would you use a rectifier to limit 12VDC current?
What is the load resistance?
georgewalker
Feb 18, 2020
14
"Why would you use a rectifier to limit 12VDC current?"
Because I wanted to limit current travelling through a12v circuit and while searching for something to do it on a component site, a rectifier was suggested.
The load resistance is variable (two electrodes in distilled water) and in the process of applying power, the resistance decreases. Controlling the current between 200mA and 400mA will limit the size of the particles emitted into the solution.
Minder
Apr 24, 2015
3,560
Sounds like you are getting into electrolysis?
A little more than just a rectifier may be needed!!;)
M.
georgewalker
Feb 18, 2020
14
M.
Yes, you are spot on. As you have guessed, I should have said regulator and not rectifier.
I have made and tested the electrolysis process (for Colloidal) simply by directing 12 vdc into two electrodes suspended in distilled water. It works but is problematic for duration and particle size.
There are two parts of the circuit I am working on.
1. Controlling the process duration while periodically reversing the polarity in the electrodes to equalize wear. This is progressing and I am waiting for parts (from China) originally due mid March at the earliest. Now Coronavirus will no doubt create further delay.
2. Limiting the current to the electrodes. Earlier I was under the impression that somewhere between 200mA and 400mA would do this but further research recommends below 40mA. This is the main determining factor in creating nano particles of Colloidal Silver.
Pretty simple to knock up a current control using a 317 regulator and a couple of fixed resistors a pot and a couple of caps.
Plenty of circuits on the web.....look up LM317 variable current regulator circuit.
14,482
This thread looks like a continuation of your last one which was moving into screwball themes and was moved and closed
are you going down the same path ?
georgewalker
Feb 18, 2020
14
Thank you. I'll look into it.
georgewalker
Feb 18, 2020
14
It is not my intention to do anything but try and create a workable circuit. I tried to change the thread title from Rectifier to Regulator but couldn't fins a way to do that.
14,482
OK .... A simple regulator circuit will regulate voltage, not current. Current limiting requires a bit more work
No, you cant do that, only moderators can. I have edited it for you :)
duke37
Jan 9, 2011
5,364
You need sufficient voltage to run the circuit. 1.25V across the sense resistor and a couple of volts across the 317 plus the voltage across the output. 6V may be sufficient. High input voltage will dissipate power and the 317 will get hot.
How do you pass current through distilled water? Water cooling of high power valves running at several kV is used, the water needs to be free of ions.
Alec_t
Jul 7, 2015
3,818
That's what I was wondering. Pure water is a very poor conductor. I've just tried two multimeter probes about 1mm apart in ordinary tap water (with goodness knows what dissolved in it) and the resistance between the probes was ~200k. It would be a lot higher in distilled water and require quite a high voltage to get even 1mA to flow (at least initially).
I've not tried electrolysis. Does a tiny initial current lead to increased conductivity and hence rising current?
hevans1944
Hop - AC8NS
Jun 21, 2012
4,985
"Electrolysis of water" discussions do indeed often lead into woo-woo "science" that is not tolerated here. What TO DO with colloidal silver produced by electrolysis of water will 99 44/100% (the "purity" of Ivory-brand soap) of the time lead directly into a woo-woo discussion. That is why the previous similar thread was terminated after it wandered away from electronics circuitry. So, please let us keep the discussion limited to electronics circuitry since that is what the ElectronicsPoint.com website is all about.
The constant-current circuit shown in post #11 is a very simple and convenient way to produce a constant current in a load referenced to power supply common. The only caveat is the regulator output voltage must be sufficiently high to drive the constant current through the load resistance. The LM317 (see attached datasheet) output voltage is adjustable up to 37 volts and requires a minimum 3 volts drop across the regulator (from input to output) to operate properly, thus the maximum input voltage is 40 volts.
The regulator design is such that it tries to maintain a constant 1.25V reference voltage across the resistance connected between the "output" and the "adjust" terminals. Since the "adjust" terminal is a high-impedance input, the current through this resistance must be supplied from a load connected between power supply common and the "adjust" terminal. This current is supplied by the regulator "output" through the resistance connected between "output" and "adjust," said resistance setting the constant current through the load connected between "adjust" and power supply common. Figure 14 "Precision Current-Limiter Circuit" in the attached Texas Instruments datasheet provides an example of how this is done.
If there is no load (electrolysis probes removed from the water) the LM317 output voltage will rise to a maximum value determined by the input voltage. There will be no regulation of the output voltage under these conditions, but no harm to the regulator either. If the regulator is supplied with only 12V DC, the output voltage may not be high enough to cause the desired electrolysis current. You can raise the input voltage from 12V up to 40V (well filtered, and this is a maximum value!) or increase the area of the electrolysis electrodes immersed in the water to reach the desired 21mA electrolysis current. If neither approach is feasible for you, someone here at EP will have to re-think the problem and find a higher voltage constant-current solution.
georgewalker
Feb 18, 2020
14
I'll build it and try it out with different input voltages and other variable. Thank you for the long explanation.
Audioguru
Sep 24, 2016
3,656
Here is the photo of a guy who ingested colloidal silver which medical experts say is not considered safe:
ATTACH=full]47174[/ATTACH]
