Ancient_Hacker said:
I have a really expensive DVM with a VFD display that is getting very
very very dim.
A new one from Noritake is $800, so that's a no-starter.
Any ideas how to pep up a fading VFD display?
it's the 19-segment alphanumeric type, one line, 20 characters.
( It looks identical to the ones on Gilbarco gas pumps. )
You first need to identify whether it is the display itself which is at
fault, or the circuitry which drives it. Dim displays fall, I would say,
roughly 50 / 50 into low drive volts, and worn out. Often, the drive volts
are derived from a voltage multiplier, and it is very common for the input
capacitor to dry out and go low value, which leads to a low supply. This is
typically about -30v DC when correct. The filament supply, which you can
normally measure at about 1.5 to 3v AC, is usually floated on top of
the -30v, so that is a good place to measure it. Most VFDs have a pair of
pins at either end of the main row. Measure across these to check the AC
filament supply, and from either one or the other to ground, to measure the
negative supply. If these are all in order, then the display is worn out.
Often, when it is worn out, there will be patches that are brighter than the
rest. You may be able to squeeze a bit more life out of it by boosting the
filament supply a tad, but if you go too far, the filament wires start to
glow a little, and may become visible. Things may be a little different with
a large 'commercial' display like this, but the basic principles should be
the same. Do you have schematics for it so that you can see how the drive
voltages are derived ?
Arfa
