Relay help (opto mos)
Rajinder
Jan 30, 2016
568
Hi all,
I have attached a schematic of an issue. I have a relay AQY212S, which is fed from a car supply of 12V. This is then switched by a relay. The relay is breaking down, I think it is due to voltage. The relay is rated at max load voltage of 60V.
I am thinking of using a diode suppression on this line, reverse stand off of 60V. Can anyone see any issues? It's a bi direction type.
Thanks in advance.
14,317
A 60 V SSR should have no issues when operated on 12 V, even accounting for the voltage spikes due to load dump.
What is the load the relay is driving? I suspect a high inrush current to be the cause of failure.
Does it fail open circuit or short circuit?
bertus
3,877
What is the led current?
What is the load of the opto-relay?
When it is inductive, you should use a Bemf diode.
Bertus
  • aqy21_s.pdf
Rajinder
Jan 30, 2016
568
It fails open circuit. it's a photo relay, MOSFET type. The load is power to a couple of circuits, one is a voltage regulator 7805, then this is used to power a opamp (non-inverting), single sided to 5V.
Rajinder
Jan 30, 2016
568
Bertus
The current of the LED
Bertus
Led current is 900uA
Load is 7805 + opamp circuit configured as non inverting amplifier. I do not think it is inductive, the current through the load is not substantial, about 50-100mA. Hence I think it is a voltage spike issue.
Rajinder
Jan 30, 2016
568
Not sure but it may because of the noisy voltage from the car battery. Also does the position of the diode look correct?
bertus
3,877
The led current of 900 uA might be marginal.
It is on the border between on and off.
Raise the led current to 3 mA for correct operation.
Bertus
Rajinder
Jan 30, 2016
568
Hi all,
Is the placement of the diode in my schematic correct? Or should it go across the output pins of the relay?
Thanks in advance
