Relay Power Rating (separate from current/voltage)
OttoVK
Apr 25, 2011
Why do relays have maximum switching power ratings? I understand maximum current ratings -- you don't want to weld the contacts or melt the device. I understand maximum voltage ratings -- you don't want to arc to the case or other components. But if a 60W relay (such as the IM03DGR) can handle 24V (if current < 2.5A), and that same relay can handle 5A (if voltage < 12V), why can't it handle 5A at 24V? What failure mode would it exhibit?
Thank you!
14,485
hi Otto, welcome to the forums
2 things that come to mind, others may input more....
As you increase the voltage for a given current, you increase the ability of that higher voltage to arc across the contacts as they are opening/closing. This will damage the contacts unless designed for those higher voltages.
As you increase the voltage and or the current, you increase the power...
W = V x I
because the resistance across the contacts is not 0 Ohms .. very low but not perfect,
the power losses in the contacts will produce heating of the contacts, which is also a bad thing
take your 60W rated relay 24V and 2.5A ... the contacts are of a size/construction to handle that
if you put 24V @ 5A you suddenly have 120W of power, twice as much as what they were designed to handle.
