Remote control electric motors
Jace Ford
Feb 12, 2018
18
How much simpler would this be if I were to eliminate the 110v motor side of things? I could potentially do that.
KMoffett
Jan 21, 2009
723
Not really any more simple. The external relays are only necessary if the internal ones can't handle the voltages and currents And that is probably the case with the information you have provided. Unfortunately most of the cheap remote receivers don't provide that spec. So just assume that you need the external relays, and choose them to meet you 12vDC and 110VAC needs.
Ken
For the 1hp motor quoted and the fact that it will be on full load continually and the fact that the motor can draw 4 times or more full load current at startup, then a contactor would be more suitable as explained earlier.
Jace Ford
Feb 12, 2018
18
So you agree with Ken's last post that the relay he linked to would be a suitable solution?
KMoffett
Jan 21, 2009
723
"DPDT contacts rated 30A (N.O.) 3A (N.C.) @ 277Vac. 1HP 120Vac:" Rated for 1HP
Ken
Jace Ford
Feb 12, 2018
18
10-4. I'll put together a little parts list with links and see what y'all think before I order.
There is no mention of "motor rating" that I can see.
Rated for 1hp not the same.
Jace Ford
Feb 12, 2018
18
I'm not really sure what to take from your post blue jets. Can you explain a little further?
The exception may be with the motor, depending on size, requiring a contactor which would be driven by the wireless relay.
yes it would be at full power the entire time that it is on.
